Engine.. mods "Cams/Pistons/Porting" Was it worth it ? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 2nd, 2008, 1:29 am   #1 (permalink)
Fly Low...
Karna's Avatar
Guys,
I know there's handful of guys that modified there Hypers... specifically engine work either cams or full system "High Compression Pistons, Head porting etc" wondering how's the engine holding up .. did anyone have to dial it in "power commander/ other solution".. second any known issues... complaints would you guys do it again ? keep it stock...
Thanks in Advance...
Karna is offline   Reply With Quote
Old May 3rd, 2008, 12:50 am   #2 (permalink)
08hyper's Avatar
Question
Don't know, I have about 4000mi now, will do the engine at 7500mi, I cant
wait!! but I heard its going to be GREAT!!
Old May 3rd, 2008, 8:27 am   #3 (permalink)
Performance Center
Ducshop's Avatar
Here is one we just finished, before run was stock HM 1100 with Termi 2 into 1, DP ECU and DP airbox lid. After is adding 100mm 11.25:1 Pistal's, DP cams, pod filters and a Rapidbike. Think porting with 2mm over intakes would be worth another 3 or 4. We got about the same with drop-in 1080 Pistal's, 2mm over intakes and porting, pods ect..
Engine.. mods "Cams/Pistons/Porting" Was it worth it ?-b-.jpg
Old May 3rd, 2008, 8:57 am   #4 (permalink)
Lifetime Premium
Images: 59
"Worth"...that's a tricky, subjective concept because beauty is in the eyes of the beholder.
I believe few would not agree that the full-boat results (i.e. exhaust, heads, cams, pistons, custom map, etc.) are pretty spectular; however, you might get some argument on the relative "worth" of such modifications.
Before one can even broach this subject, there needs to be a clearly defined mission statement for the bike.
So, Karna, how do you intend to use it? Are you commuting on it or racing it? Depending upon how you answer that question, the "worth" answer could follow any number of different vectors.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old May 3rd, 2008, 9:23 am   #5 (permalink)
ZX10R's Avatar
Location: Near Rotterdam, Zuid-Holland, The Netherlands
I like it, the Hyper really kicks ass up to the rev limiter. Before it was over at 5500-6000 rpm.
ZX10R is offline   Reply With Quote
Old May 4th, 2008, 8:46 pm   #6 (permalink)
Here one that Chris at Moto Corse Performance in Ft. Lauderdale has done a few month back , 3000mls later still purring like a kiddy.
Engine.. mods "Cams/Pistons/Porting" Was it worth it ?-dyno-105.jpg
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Old May 4th, 2008, 11:21 pm   #7 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
More HP and torque is nice but to be honest, I think I have all I need right now. I have the cams to put in later but I've put a lot of effort in getting the intake/exhaust and fueling right to get the most out of the stock engine. Now its smooth, with very broad power and excellent response. Not sure if I'm going to like the cams but I'll probably put them in later with a set of 1123 Pistal pistons cause I can't leave well enough alone.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old May 14th, 2008, 1:14 pm   #8 (permalink)
dutchduc900's Avatar
Images: 14
I have a 1000SS for the track. Just had the DP cams installed. Engine mods now include:
- open airbox
- special/wider diameter exhaust headers and open exhaustst (with db killers installed)
- heads ported
- dp cams
- PCIII with seperate maps for each of the cylinders (quite some difference)
Results rear wheel: 107 HP and 114 Nm (84 ft-lb) Gain after cam installation was 11 HP and 6 Nm. Very small performance loss under 4000 rpm.
Quite please with it, just had 3 trackdays at the Assen MotoGP/WSBK racetrack ;-), and yes, it is worth it at the race track. I wouldn't do it for normal road use so I'm gonna keep my MTS 1000S standard.
dutchduc900 is offline   Reply With Quote
Old May 14th, 2008, 5:34 pm   #9 (permalink)
Lifetime Premium
Images: 59
Originally Posted by dutchduc900 View Post
...Quite please with it, just had 3 trackdays at the Assen MotoGP/WSBK racetrack ;-), and yes, it is worth it at the race track. I wouldn't do it for normal road use so I'm gonna keep my MTS 1000S standard.
So, Karna, what's the mission statement for your bike? Track or Road? DutchDuc900's comments pretty much says it all.
Or, perhaps, you don't have a mission statement at all and are just a perennial teeker like DukePilot
Bill
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old May 14th, 2008, 7:18 pm   #10 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Yup that's my mission, enough is never enough!
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Crankcase Ventilation System Shazaam Hall of Wisdom 2 Feb 24th, 2012 10:29 am
Ducati Cooling System Shazaam Hall of Wisdom 3 Nov 20th, 2010 10:26 am
What's it worth?! hammerwoman Supersport 7 Mar 14th, 2008 11:16 pm
Engine Warning Light davemcqueen Sport Classic 4 Jul 12th, 2007 1:08 pm
Blew engine on one-day owned 748...what should I do? Desmo Soundtrack Superbikes 17 Jul 2nd, 2006 9:39 am
