How to reset clock? Too lazy to read manual - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 1st, 2008, 11:35 pm   #1 (permalink)
Anybody got a quick answer for clock time resetting? I'm too lazy to dig up the manual and can't seem to intuitivly do it like I can on the BMW.
Hypermotard S, too broke for mods
Other bikes - BMW 1200GSA & Honda XR400
socalrob is offline   Reply With Quote
Old May 1st, 2008, 11:47 pm   #2 (permalink)
AXE
AXE's Avatar
I am too lazy to look for you too, but here is what I remember. Turn on your key and scroll down til you get to the clock. Once you find the clock hold the button down untill it flashes. Then use the lever on the front side of the horn/toggle housing to adjust the time. Toggle between the digits by hitting the down button again. Once you have the time set, hold the down button down and it will go back to normal mode.
Now that I think about it, I am not sure any of that really works, but I know that if I tried it, I would figure it out in a couple tries. So go ahead and just try if a few ways.
Out!
2008 Ducati Hypermotard
Old May 2nd, 2008, 12:04 am   #3 (permalink)
Figured it out, of course the bike may not start tommorrow.
You have to push the slide lever up and toggle through the screens and there is a set clock screen (toggle through the lap timer and such).
Then it is a matter of fooling around with the slide switch and the bright flash lever on the back.
Old May 2nd, 2008, 12:25 am   #4 (permalink)
AXE
AXE's Avatar
Yeah, that's about the way I did it too. Punch a lot of buttons see what happens. Mine did start, so I think your good to go.
Out!
Old May 2nd, 2008, 5:00 am   #5 (permalink)
MarksFriggin's Avatar
You shouldn't have to use the bright switch to change the clock time. It's all done with the slide.
Old May 4th, 2008, 1:45 pm   #6 (permalink)
Jeff4510's Avatar
trip odo reset?
Out!
same way to reset that one?
Jeff4510 is offline   Reply With Quote
Old May 4th, 2008, 3:55 pm   #7 (permalink)
Trip odo reset is just hit the slider down to get to the trip odo, then push down again and hold it until it sets to zero.
Old May 4th, 2008, 6:53 pm   #8 (permalink)
Thanks for the info. I was resetting mine by pulling the positive battery cable. This new method will make my gas station visits lots faster.
Ducati Manual Darkness Superbikes 11 Aug 6th, 2008 10:49 pm
replacement manual and service manual? japhar81 Supersport 3 Jun 28th, 2006 4:19 pm
ST3 Shop Manual Purchase Warning: the '04 - '05 conection stryder Sport Touring 6 Mar 10th, 2006 9:33 am
