L.E.D Front indicators - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 1st, 2008, 1:59 pm   #1 (permalink)
Hi,
I know some of you Hyper owners have fitted small front L.E.D indicators, I plan to do the same and am wondering if it is simply a case of just connecting them up to the original front indicator wiring? or do they need a resistor of some kind to get the correct flashing rate? Please advise.
Regards,
Duncan.
duncanmiller is offline   Reply With Quote
Old May 1st, 2008, 4:01 pm   #2 (permalink)
I installed Oberon bar-end LED turn signals on the front of my Hyper and the flash rate is the same as stock. Oversimplified, it was just a matter of connecting the wires.
hypermax is offline   Reply With Quote
Old May 1st, 2008, 4:08 pm   #3 (permalink)
Smile Thanks hypermax
I was hoping that would be the case as the original fronts are also L.E.D, that sounds promising thanks. I am going to swap the handguards for some proper Acerbis ones so obviously need to sort out alternative indicators.
regards,
Duncan.
Old May 2nd, 2008, 11:20 am   #4 (permalink)
HyperMotard21's Avatar
Images: 61
Have a look at what I installed to indicate my alarm. It comes in yellow colour too. About USD15 for a pair. Rubberized and bendable. Very bright. Maybe your accesorries shop has them
Scorpio alarm issue?
A HyperTard on a HyperMotard
HyperMotard21 is offline   Reply With Quote
HELP! Front BRAKE seized SOLID! Crashed 996! christ Superbikes 18 Apr 9th, 2008 12:57 am
Changing to a lighter front rim ??? ZDM Superbikes 2 Mar 12th, 2008 5:24 pm
Alternative Handguards n Front Signal Indicators gssm HyperMotard 9 Oct 29th, 2007 10:07 am
I got my Front Axle out... AND MY BIKE SLIP OUT OF THE STAND! actionong Superbikes 11 Feb 20th, 2007 4:13 pm
