Tired of Tip-Toeing!! I need a rear shock ride-height adjuster. - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 1st, 2008, 9:47 am   #1 (permalink)
Anyone have a deal on the rear shock ride height adjuster?
I have the non-s model so I cant lower the bike at all and need that!! I KNOW someone will post i should just leave it be and ride it high, but I use it as a daily commuter and its tough at every f'in light to lean to one side and tip-toe. i already changed the seat out.
cincykid is offline   Reply With Quote
Old May 1st, 2008, 1:19 pm   #2 (permalink)
Werloc's Avatar
Images: 6
I have the same problem, but it's not really a problem. I can deal with it. I would "think" this would change the rake of your front forks if the rear is lower and change the handling a little. I'm no expert, I'm just kinda asking this myself. Just a thought. I may be interested in the very same thing for my bike "if" it doesn't make a big difference in the way it handles.
BTW, How much lower is the other seat you have and is there enough padding on it for long full day rides?
Werloc is offline   Reply With Quote
Old May 1st, 2008, 3:25 pm   #3 (permalink)
I have a spare one, brand new in the Ducati box that I'd be happy to sell you. $100 plus $10 for FedEx 3 day shipping. You can send me an e-mail if you are interested. richard.rohrich^@^gmail.com (remove the ^ jobbies )
Lowering the rear and the pulling up the forks the same amount worked great for me. I've ridden my lowered S version back to back with a stock height S and I much prefer the lowered version.
Rich
exotherm is offline   Reply With Quote
Old May 1st, 2008, 4:47 pm   #4 (permalink)
yota's Avatar
here's my standard model with the optional rear link as low as it will go and the front adjusted to level.
yota is offline   Reply With Quote
Old May 1st, 2008, 9:26 pm   #5 (permalink)
Werloc's Avatar
Images: 6
Rich
Check your Gmail.... Also sent you a PM...
Old May 2nd, 2008, 7:13 am   #6 (permalink)
Exotherm, I will take it. Should I just paypal you?
Old May 2nd, 2008, 7:16 am   #7 (permalink)
Yota, how many MM down in the front did you go? I figured the forks will be almost right against the bars at that point (not that it bothers me).
Also regarding Werloc's question about the seat. I bought the "DP Comfort seat, I would say its a little more comfortable than the stocker but BARELY lower, if at all. The longest i have ridden straight was last Sunday for about 3 hours or so and i was fine. I did notice because the material is slightly different than the stock seat, you can't slide across it super easy for serious leaning, but it wasnt a huge deal, just discovered the new seat was a little more "sticky" than the stocker.
Old May 2nd, 2008, 8:28 am   #8 (permalink)
[QUOTE=exotherm;402779]
Cool. I got your e-mail and I'll send you the specifics when I get back into work. I should be able to drop it off at FedEx tonight.
If it will stop raining here I'll shoot a picture of the fork position.
Old May 2nd, 2008, 8:49 am   #9 (permalink)
Exo, you didnt mention if I should paypal you or what your paypal address is. Call me if you want to, 513-615-4800. Thanks again. Shane
Old May 2nd, 2008, 11:15 am   #10 (permalink)
HyperMotard21's Avatar
Images: 61
I'm 5'6" (168cm) and yeah I tip toe to the max. I have an S and was told it's already at it's lowest for rear stock.
My alternative is to shave the seat by a few mm. It's easily done but I have yet to really bitch about tip toe-ing for now. We'll see how it pans out. Only been a month for me
A HyperTard on a HyperMotard
HyperMotard21 is offline   Reply With Quote
Standard ride height specs Corse1 Sport Touring 9 Feb 19th, 2008 12:52 pm
ST-3 Rear Shock Replacement vincep Sport Touring 4 Jul 29th, 2006 8:02 pm
'02 ST4s rear ride height adjustment??? mad Sport Touring 10 Jul 21st, 2006 6:00 pm
Eye bolt ride height adjuster thingy TrojanHorse Superbikes 3 Mar 31st, 2006 2:27 pm
Ride Height adjuster DukeDesmo Superbikes 20 Mar 10th, 2006 11:23 am
