Originally Posted by dukepilot
You will want to keep the DP open airbox lid unless you're going to eliminate the airbox completely. The ECUs are not coded to the bike so you can sell your stock and slip-on ECUs if you want. You will need to have your TPS reset and fuel trim adjusted with each ECU swap. That's going to be one expensive exhaust system when its complete. Hope you're getting a good deal on it!
I am a sponsored by a Ducati dealer so I would never think of doing this otherwise, the cost savings make it somewhat feasible plus I can spread out my purchases doing it this way.
The mid-pipe comes with a airbox cover as well so that is why I would have a cover for sale. Hopefully I can recoup some of the costs with the sale of the slip-on ECU and airbox cover.
It is awesome that we can actually intechange our ECUs now!
Tphnet....does your DP ecu work well with the Zard pipes? The reason I ask because of the lack of control on the exhaust valve and does the CO2 sensor get reinstalled in the Zard system?
