Just wanted to say Thanks! - Ducati.ms - The Ultimate Ducati Forum
Old Apr 22nd, 2008, 6:57 am   #1 (permalink)
Having the BBS is like having your own 1-800 tech crew to call. I know it sounds stupid, but I wanted to adjust the chain on my Hyper last night and after having owned 99% sportbikes with standard swingarms, I was bent thinking I would have to buy a f'in spanner wrench. Did a little searchy search and found in another post that you can loosen the 2 bolts and grab a hold of the chain gauard and BAM, done in about 2 minutes. Its nice having this "support group" 24 hours a day.
Hi, my name is Shane Williams, and I am addicted to motorcycles.
cincykid is offline   Reply With Quote
Old Apr 22nd, 2008, 11:45 am   #2 (permalink)
AXE
AXE's Avatar
So where's the thread? I am about to do mine too.
Thanks!
2008 Ducati Hypermotard
Old Apr 22nd, 2008, 12:03 pm   #3 (permalink)
Here, let me tell you how......:-)
Get the back end of the bike off the ground (rear stand or however you choose). Take a 14 MM deep socketand shorty extension on your 3/8" ratchet and simply break the 2 bolts on the top of the "hub" on the rear wheel. While sitting on the left side of the bike at the rear wheel, take your right hand and literally grab the chain guard and pull it towards the back of the bike. It will start to rotate down, thus pulling the sprocket assembly back with it. Tighten the bolts down a little, drop the bike, check chain tension, if good, tighten the 2 bolts back up all the way, otherwise lift her back up and loosen or tighten the chain to desired tension.
It literally was that easy.
Old Apr 22nd, 2008, 1:34 pm   #4 (permalink)
husky's Avatar
I believe that the tool kit has a spanner wrench. I maybe wrong but my 996 had one.
Present:
2006 Husky sm610
2009 Black MV Agusta Brutale 1078rr!
Past:
2000 RC51
2001 Yellow 996
2008 Hypermotard
2005 gsxr1000
husky is offline   Reply With Quote
Old Apr 22nd, 2008, 3:51 pm   #5 (permalink)
MarksFriggin's Avatar
No spanner in the Hyper tool kit.
Old May 11th, 2008, 1:13 pm   #6 (permalink)
ducatichick's Avatar
Anyone have an exploded view of the swing arm & chain adjust mechanism from the manual?
ducatichick is offline   Reply With Quote
Old May 11th, 2008, 5:27 pm   #7 (permalink)
Like this?
Old May 12th, 2008, 10:29 am   #8 (permalink)
Yeah, thanks!
Unless there's a "dummy's guide" image to adjusting the chain...it's been 11 years since I had my 916 and can't remember how the adjuster works. Those Italian engineers are clever .
Wanted!! dk65 Supersport 4 Feb 8th, 2008 12:01 pm
I test drove a HM and wanted to like it LeviSS HyperMotard 22 Dec 15th, 2007 2:41 am
Sport Classic part wanted dietrichpfeifer Sport Classic 3 Mar 1st, 2007 7:35 am
