Termi Slipon/Zard Collectors Installed - Ducati.ms - The Ultimate Ducati Forum
Old Apr 20th, 2008, 6:39 pm   #1 (permalink)
daversj's Avatar
I bought the Zard collectors from Desmoworks. He shipped them fast and they went on realy easy. I was actually able to leave the slipon installed while putting on the zard pipes. I installed the headers first loosly and then the mid pipe. I slipped the midpipe into the muffler end first and then collectors. Installed springs, tightened header bolts and lastly the muffler clamp. The aluminum support bracket for the cat has to be removed which reveals a hole for the new bolt. You will need some washers equal to the thickness of the bracket to shim the foot peg bracket. I also had my friend cut off the ugly heat shield and grind it smooth. I buffed the pipes with red Scotchbrite and then degreased them. After warmup they turned a nice golden silver color. I neglected to locktite the big bolt so after one ride it's gone. At $500 I'm pleased to not have bought the Termi ones. The quality of the Zard parts is very good with the exception of the heat shield. They sound mean and between the cat and valve thing I probably shed 5lbs.
daversj is offline   Reply With Quote
Old Apr 20th, 2008, 6:42 pm   #2 (permalink)
MarksFriggin's Avatar
Looks like a nice set up. Very nice.
Old Apr 20th, 2008, 8:58 pm   #3 (permalink)
AXE
AXE's Avatar
Sweet! Now that I have my Zard Top Guns on, I am gonna do the header and cat eliminator soon. I think I am gonna coat mine black. I agree, ditching that heat shield is well worth the headache.
Out!
2008 Ducati Hypermotard
Old Apr 27th, 2008, 4:39 am   #4 (permalink)
slowpoke's Avatar
What's the advantage of eliminating the CAT? Does it get rid of the "choppy" throttle?
slowpoke is offline   Reply With Quote
the full termi is a DEAL at $2000 rubyvrooom HyperMotard 81 Jan 12th, 2008 12:38 pm
Warrantee invalidated by self installed termi system? JARED Superbikes 16 Jul 28th, 2007 10:07 am
Termis installed!, a few questions/oservations ducatisRme Sport Classic 16 Jun 14th, 2007 9:30 pm
Advice needed 749 w/ Termi ECU? sludge Ducati Motorcycle Chat 3 Jun 8th, 2007 6:16 pm
Installed Termi Half System on 999 Fly999 Superbikes 14 May 16th, 2006 9:36 pm
