Duc is dead part 2 - Ducati.ms - The Ultimate Ducati Forum
Old Apr 14th, 2008, 9:45 pm   #1 (permalink)
Duc is dead part 2
Well, I got the call from the dealer today. They said that the reason it is running like crap is because the rear cylinder is not holding compression. He thinks that one of the springs on the exhaust valve closers has broken. Has anyone else ever seen a problem like this. This is my first duc so I don't know much about the common duc problems.
speedfreak is offline   Reply With Quote
Old Apr 14th, 2008, 10:04 pm   #2 (permalink)
08hyper's Avatar
Red face
Don't think its a common problem, the 1000/1100 DS motor is a well proven
motor, maybe yours was put together on Fri afternoon? sorry about your problem, at least you have a 2 year warrantee. Aloha Alex
Old Apr 15th, 2008, 8:08 am   #3 (permalink)
shat's Avatar
I don't think so...The springs are there for enhanced starting. Once started, the spring tension plays very little if no role in engine performance. I've raced DESMO singles without any springs installed. Red Herring in my book.
Steve
shat is offline   Reply With Quote
Old Apr 15th, 2008, 9:01 am   #4 (permalink)
thoroughly addicted
The first-year (2004) ST3 had a problem with exhaust valve springs breaking. There was a recall. The symptoms were poor idling and low speed performance as I recall.
Debby
In the garage:
07 GT1000, gray
Previously in the garage:
65 250 Scrambler
02 998 Mono
07 Hyper S
97 900 SS/CR
67 250 Scrambler
debby is offline   Reply With Quote
Old Apr 15th, 2008, 7:57 pm   #5 (permalink)
Well, I got the word today. A cam pully came loose and jumped a tooth. Probably tinged a valve. Waiting on the Ducati service rep to approve the warranty work so they can get started.
Old Apr 16th, 2008, 5:11 am   #6 (permalink)
shat's Avatar
Maybe there's more potential loose cam pulleys out there. I for one will be pulling my belt covers and checking. If timing is off, piston to valve collision is possible. Doesn't take much to bend a valve. I know. Thanks for keeping us all in the loop.
Old Apr 16th, 2008, 9:23 am   #7 (permalink)
Lifetime Premium
donkeyman's Avatar
How long will it take to get the job finished and the hyper back on the road?
donkeyman is offline   Reply With Quote
Old Apr 18th, 2008, 7:43 pm   #8 (permalink)
Well after waiting 3 days for the Duc service rep to authorize the work they can finally get started on the teardown tommorow. I actually saw what happened and it was the nut that holds the two lower pullys on wasn't tight enough. This let the pullys move just enough that they started wearing on the pullys, the shaft, the keys, and the keyways. It eventually built up just enough wear and slop that the rear valve just tapped the piston. They said best case it would be a week and a half, worst case 3+ weeks depending on parts shipping and condition of the heads and valve guides once they get in there. Wish I had the extra cash, it would be a good time to put in the cams, head porting, pullys, pistons, etc. Oh well, I will be happy to have it just run right again.
Old Apr 18th, 2008, 11:23 pm   #9 (permalink)
parkcrf's Avatar
Sounds like the perfect time to get headwork, etc.. done.
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Apr 19th, 2008, 4:22 am   #10 (permalink)
HyperWeaseL's Avatar
sorry to hear that hope you get it working soon
HyperWeaseL is offline   Reply With Quote
Tye's official 848 review part 1 tye1138 Superbikes 46 Jul 20th, 2009 9:53 pm
Tye's Official 848 review part 2; On the track tye1138 Superbikes 28 Jul 2nd, 2009 1:25 pm
Duc is dead speedfreak HyperMotard 16 Apr 8th, 2008 6:43 pm
Dead Duc, big bucks to repair. Sell or trash? ST4R Sport Touring 7 Apr 1st, 2008 10:48 pm
1098s/r and 848 Interchangeability joeyrotorhead Superbikes 19 Feb 19th, 2008 3:34 pm
