Bad 2-1-2 ECU? need proof, please help - Ducati.ms - The Ultimate Ducati Forum
Old Apr 14th, 2008, 1:15 pm   #1 (permalink)
jonvan's Avatar
I have heard on this site of some bad ECU's (the ones installed with exhaust upgrade). I upgraded my exhaust before I took delivery of bike and am curious if I have a "bad" one (lack of power). I don't have a reference point.
I asked my dealer and he laughed (really) at me because I heard it on the internet. He checked the service bulletin's and seems to want to stop there.
MY QUESTION: How do I know difinitively that I have a faulty (lack of power) ECU? Is there documented proof of this problem?
Please help
Jon V
jonvan is offline   Reply With Quote
Old Apr 14th, 2008, 2:31 pm   #2 (permalink)
johnchypermotard's Avatar
i am making an assumption that you are referring to a dp ecu upgrade ...
1. replace the questionable dp ecu with your stock ecu, and ride the bike. if the lack of power issue is resolved, this is a pretty good indication that the dp ecu is faulty.
2. get the bike on a dyno with the dp ecu and do a run. then install the stock ecu and do a run. compare the two run graphs ... this will provide you with documented proof to get the dp ecu replaced under warranty if it is faulty.
if after doing either/both of the above, the bike's issues are not identified/resolved, ask your dealer if they reset the TPS when they installed the ecu and exhaust.
best of luck with your dealer ... i know i would change dealers if they laughed at me when i asked a question on warranty of a bike i purchased from them.
Old Apr 14th, 2008, 4:16 pm   #3 (permalink)
ZX10R's Avatar
Location: Near Rotterdam, Zuid-Holland, The Netherlands
Put it on the dyno, like johchypermotard wrote.
ZX10R is offline   Reply With Quote
Old Apr 14th, 2008, 9:20 pm   #4 (permalink)
Unhook your exhaust valve cables at the servo and road test. Mine picked up considerable power. I had a pre-termi installation as a reference. I am in the process of getting a new ECU. I hope.
bbenn75820 is offline   Reply With Quote
Old Apr 15th, 2008, 7:45 am   #5 (permalink)
Abarth's Avatar
At what milage is it "safe" to put the bike on a dyno? I assume not before the 1000 km (600 miles?) point is passed?
Abarth is offline   Reply With Quote
Old Apr 16th, 2008, 1:58 am   #6 (permalink)
ZX10R's Avatar
You can even break it in on a dyno.
http://www.mototuneusa.com/break_in_secrets.htm
Is ECU Modification Possible ??? SanDiego Sport Classic 7 Mar 30th, 2008 8:52 am
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
2002 st4s ecu gvinall Sport Touring 5 Mar 20th, 2008 11:11 am
powercommander, rapidbike, techlusion, DP ECU, or ultimap? stlouisrider Sport Classic 5 Mar 14th, 2008 9:36 pm
