Zard Top Guns - Ducati.ms - The Ultimate Ducati Forum
Old Apr 14th, 2008, 12:37 am   #1 (permalink)
AXE
AXE's Avatar
Zard Top Guns
I just got around to getting my Zard Top Gun slip ons installed tonight. Here are a few observations
  • Sounds incredible, (with no baffle you might find it a bit loud)
  • Quality construction
  • Fitment is good (however, it could be a little better in terms of the carbon fiber side panels fitting to the stock covers, and they had them reversed as shipped)
  • Finsh is average (the carbon fiber isn't as good as it should be, and one of my side panel pieces is pitted badly)
  • Sounds incredible
  • There are a lot of pieces assembled to make this kit
  • Tail kit is average (I am going to use the one I fabricated and modify it to fit the Zard)
  • Definitely longer than stock pipes, but much lighter
  • Packing was very good, but the loose side panels did rub on my can and messed up the finish a little bit
  • Sounds incredible
Anyway, once I get the rest of the bike back together and my tail kit modified and rewired I will post some pictures and sound clips.
Out!
2008 Ducati Hypermotard
Old Apr 14th, 2008, 7:35 am   #2 (permalink)
SuperGeorge's Avatar
You forgot to tell us : how do they sound???
Can wait for the pics
SuperGeorge is offline   Reply With Quote
Old Apr 14th, 2008, 12:18 pm   #3 (permalink)
Images: 5
Thanks for the update!
Are you using any sort of ECU modifications and/or did you have to fiddle with the TPS with just the slip-on?
zekiel is offline   Reply With Quote
Old Apr 14th, 2008, 12:51 pm   #4 (permalink)
euromotoaz's Avatar
I really like the way the Zards look. They really change the appearance of the bike, but I like the Arrows too. They're somewhat understated but tasty.
Ciao,
Euro Moto Arizona, LLC
Tom Fucili - President
tom@euromotoaz.com
Victor Castaneda Jr. - Operations Manager
victor@euromotoaz.com
(877)684-5725
DUCATI.ms MEMBERS GET A 10%DISCOUNT BY USING COUPON CODE ducatims2008 AT CHECK OUT.
www.euromotoaz.com www.myspace.com/euromotoaz
euromotoaz is offline   Reply With Quote
Old Apr 15th, 2008, 1:06 am   #5 (permalink)
AXE
AXE's Avatar
I have the DP ECU I picked up from a board member. I also have a DNA filter and modified the stock lid. The bike ran pretty well with just the filter, air box mod, and DP ECU. I suspect that it will run pretty well with the added pipe too. I am going to try and get it on the dyno later this week or early next to get it dialed in just right.
Right now, I am still in the process of modifying the tail kit. The mounting bracket the Zard supplies is a nice piece, but it is made for the stock blinkers. I am modifying it to work with some Motrax LED blinkers. I am having to do some fab work with it. I got it mocked up tonight, so I like how it sits on the bike. I also mashed the pipe that holds the wiring down to a flatter profile so it sits tighter up to the exhaust that made it look better. I have to figure out how to attach the smaller blinkers. I may also paint it black too.
I can't wait to hit the road with it, but it will probably take me a few more hours to get the wiring done and the side panel inserts adjusted. It is a bigger project than I was looking for, but should be nice when I get it done.
This thing growls...............I guess loud pipes saves lives.........at least on a Harley. The video clip on YouTube is pretty much spot on in terms of sound.
Out!
"Wasp TMSD" - Top Mount Steering Damper wasp1000 Sport Classic 205 Oct 9th, 2009 1:05 pm
Zard Hyper In Stock! desmoworks Pro Italia/Desmoworks 3 Apr 12th, 2008 9:26 am
Paul Smart Fairing & Zard Exhaust Combo? impax11 Sport Classic 6 Feb 28th, 2008 3:44 pm
Another Zard Exhaust Post david999duc Superbikes 3 Sep 13th, 2007 6:37 pm
