Will A Used Ecu Work On My Bike? - Ducati.ms - The Ultimate Ducati Forum
Old Apr 10th, 2008, 9:39 pm   #1 (permalink)
daversj's Avatar
I'm adding the Zard header to the termi slipon. Will a used ECU from another bike work on mine after reset? I'm considering a used ECU from a termi 2-1 setup. If I buy the Technoresearch tool can I do it myself?
daversj is offline   Reply With Quote
Old Apr 11th, 2008, 10:33 am   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
It should work assuming that the ECU is not damaged. You can reset the TPS with the Technoresearch scan tool and adjust fuel trim but you will need a gas tester to do it correctly. Disconnect the battery before you install the ECU, just as a precaution.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Tye's official 848 review part 1 tye1138 Superbikes 46 Jul 20th, 2009 9:53 pm
I Need An Excuse GusGus748s Superbikes 27 Jun 28th, 2006 2:40 pm
You know its time to work on your bike when... scottrwilliams Superbikes 0 Jan 23rd, 2006 2:38 pm
