clutch and rear brake fluid dark - Ducati.ms - The Ultimate Ducati Forum
Old Apr 5th, 2008, 9:26 pm   #1 (permalink)
hyperdookie's Avatar
Images: 9
Bike has barley 600mi. and the fluid in the reseviors for the clutch and rear brake is much darker than the front brake. Is there any reason for this other than the difference in the volumes of these systems? Anyone else seeing this? Should I flush, or just shut up n' ride?
Old Apr 5th, 2008, 9:30 pm   #2 (permalink)
totnac's Avatar
i noticed the same thing on mine....i only have 375 mls...
Anthony
totnac is offline   Reply With Quote
Old Apr 5th, 2008, 10:53 pm   #3 (permalink)
AXE
AXE's Avatar
Normal.......my dealer mechanic that did my pre-delivery walk through actually told me to expect that from the clutch cylinder.
Ride more, worry less!
I just got some Rizoma billet fluid cylinders and can't wait to post up some pictures. With those, you will never know the color of the reservoirs.
Out!
2008 Ducati Hypermotard
Old Apr 6th, 2008, 9:17 am   #4 (permalink)
HyperMotard21's Avatar
Images: 61
I got just about 200 miles and mine's dark too.
A HyperTard on a HyperMotard
HyperMotard21 is offline   Reply With Quote
Old Apr 6th, 2008, 10:49 am   #5 (permalink)
lelenb's Avatar
Images: 12
I changed and flushed both systems and within two rides they were dark again. I am going to install a STM clutch slave and I hope this will help. I am wondering is this discoloration is from o-ring wear?
Lelen
Hyper S
Old Apr 6th, 2008, 11:04 am   #6 (permalink)
MultiDoc's Avatar
Images: 49
Lightbulb
Gentlemen, don't worry about that. It's perfectly normal and expected to happen. It's mostly because of the extra heat these 2 reservoirs are exposed to, compared to the front brake (see the route where the line goes for the clutch cylinder and also see where the exhaust pipe is in regard to the rear brake reservoir ).
No flush is required or will help, it will be dark really fast again. Also no O-ring wear is to blame for this either, and of course an aftermarket slave clutch won't help (for discoloration, but it will certainly be a very good upgrade).
Doc
N3R Team #166
DP: Full Termi 57mm+filter+ecu, belt rollers, racing seat, monoposto tail, rear hugger, rear sprocket, ram-air covers, keyguard, carbon fuel cap, titanium reservoir covers, billet clutch & sprocket covers, monoposto subframe, MBP collets,STM: 48T clutch basket & plates, clutch slave cylinder, Suter Racing slipper clutch, Öhlins: forks+shock+steering damper, BrakeTech iron rotors f/r, R&G sliders f/r, ValterMoto rear axle sliders, SpeedyMoto: under-body sliders & water pump cover, Samco hoses, AFAM X-ring chain, Fabbri screen, Evoluzione throttle, PT levers, Marchesini forged mag rims, Woodcraft clipons, ProGrip's, FrenTubo kevlar lines f/r, Rider's Racing rear caliper bracket
MultiDoc is offline   Reply With Quote
Old Apr 6th, 2008, 12:10 pm   #7 (permalink)
Dark_Daddy's Avatar
Images: 10
I am going to +1 on Docs statement. I usually bleed my rear brake about once a season and I have a Evo slave Cyl. on mine too. I have experienced rear brake failure twice now and the heat generated near the reservoir is terrible I had a guy measure it at 136 degrees on an infrared thermometer. I really only use my rear brake for stoplights and hills to give my clutch hand a rest.
Chris
2006 749 Tricolore FOR SALE
Dark_Daddy is offline   Reply With Quote
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 6 May 19th, 2011 9:00 am
HELP! Front BRAKE seized SOLID! Crashed 996! christ Superbikes 18 Apr 9th, 2008 12:57 am
Buying an 800SS tomorrow...any toughts? suba007 Supersport 23 Apr 5th, 2007 1:46 pm
Nuetral problem... revolucien Superbikes 13 Apr 28th, 2006 8:12 pm
