Anyone with a "Base" HM change rear shock yet? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Apr 2nd, 2008, 9:32 am   #1 (permalink)
I was curious if anyone had changed out their rear shock for something with a remote preload adjuster, like the Ohlins on the MS-S. Did you also change out the rear spring? A local suspension guru tells me that the stock spring is probably the weakest point and will give it up in just a couple thousand miles. Anyone tried the Bitubo shocks?
Rear shock upgrade? gorma900 Supersport 21 Apr 17th, 2009 6:08 am
Rear Shock dancinkozmo Supersport 21 Feb 29th, 2008 3:12 am
749 rear sprocket change fronkfronk Superbikes 21 Aug 22nd, 2007 5:47 pm
999 rear sprocket change, can someone help me out? archer Superbikes 5 Jul 13th, 2007 5:17 pm
