The Cam kit, comes with Cams + ECU
It not recommended to install this kit, unless you have the 2-1 Termi race kit (which comes with an Airbox lid, Full heather with cat eliminator, few plastic/CF pieces to close off the tail piece, and yes! an ECU), or another after market equivalent
In other words, if you buy both kits you will end up with two ECU's, of which the one that came with the Termi kit will earn you $300 as you will put it for sale, and using the Cams ECU instead.
The Termi full kit is around $2500
The Race Cams kit is around $500
The work to install both is around 8 hours (at around $90 per hour) = $720
Total cost= $3720 - $300 (ECU sold) = $3420
Value = around 10-15 HP + great exhaust note - 20 pounds
While in the ZONE there is no I
