Steering Head/Triple Clamp Alignment? - Ducati.ms - The Ultimate Ducati Forum
Old Mar 30th, 2008, 3:02 pm   #1 (permalink)
AXE
AXE's Avatar
I noticed yesterday that my triple clamp and associated steering components seems to be slight turned about a 2-3 mm to the right when I look down at the steering head.
The bike handles well and tracks straight as an arrow, so it appears to not be a problem. I never noticed it before yesterdays long ride, but it started to bug me once I noticed it.
Is there any kind of simple adjustment that can be made to realign or trim it a little bit, or will it require total adjustment of everything including aligning the front wheel again.
Thanks!
Out!
2008 Ducati Hypermotard
Old Mar 30th, 2008, 3:26 pm   #2 (permalink)
lelenb's Avatar
Images: 12
Well on dirt bikes I have put the bike on a stand and loosened the triple clamps and twisted the handle bars left to right while I hold the front tire between my legs. This usually removes the torsion caused by a dirt bike crash. You may need to spread open the triple clamps with a tire iron after you loosen the bolts if the forks are still held tight. Be sure to tighten the triple clamps in small increments to even out the torque between the bolts.
Lelen
Hyper S
Tank-Slappers Shazaam Hall of Wisdom 24 Mar 6th, 2010 11:53 am
"Wasp TMSD" - Top Mount Steering Damper wasp1000 Sport Classic 205 Oct 9th, 2009 1:05 pm
Model differences in steering / steering damper AAL Sport Classic 9 Sep 9th, 2007 1:21 pm
Wheel/Chain Alignment Technique!!! galaxy Ducati Motorcycle Chat 4 Jun 18th, 2006 10:07 pm
Winged upper triple clamp for 749/999? Now where did I see that? rustysrustyduc Superbikes 3 Mar 21st, 2006 12:42 pm
