Power Card fuel controller - Ducati.ms - The Ultimate Ducati Forum
Old Mar 28th, 2008, 3:48 pm   #1 (permalink)
lelenb's Avatar
Images: 12
Has anybody ever used a Power Card fuel controller? I am thinking of getting the Rapidbike 3 for my Hyper and I just happened to come across this.
http://www.powercardtuning.com/produ...les/index.aspx
I like the idea of keeping the oxygen sensor for real time fuel mapping instead of a fixed fuel map. They make one for the Multistrada DS1000 engine, but not for the DS1100 engine. I sent them an email to see if they intend to produce one for the Hyper and I have not heard back from them. Essentially what the controller does is intercepts the signal to the fuel injector and change its pulse width. They also intercept the signal from the oxygen sensor so the ECU will not try to trim the fuel output based on the richer reading. Are the electronics on the DS1000 & the DS1100 the same? I know people were using the DS1000 PCIII on their Hypers in the beginning.
I did just read on their website that the DS1000 motor was pre O2 sensor so I think this rules out it's use, but maybe...
Lelen
Hyper S
Old Mar 29th, 2008, 12:49 am   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Not on the market yet for 02/closed loop Ducs. If it does hit the market it may only affect open loop tuning like the cal compliant pc3.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Mar 29th, 2008, 10:48 pm   #3 (permalink)
Home of vortex tuning
CDONA's Avatar
TFI, Power card, has been one of the faves in the V-rod world it is a clone of the Screaming eagle race fueler and Gill's box The pro card does have the O2 (busy signal). maybe one for the flapper too. This box is what I want, add fuel only, no timing change/fuel reduction, plug N play and back to stock emissions, no shop time. Put me down for one too.
Old Mar 29th, 2008, 10:56 pm   #4 (permalink)
BigHoss's Avatar
That's a sweet set up. any one with pros or cons? Still learning about the ECU and fueling. I am an old carb kinda guy.
BigHoss is offline   Reply With Quote
I added the wrong FUEL!!! beestiboy Ducati Motorcycle Chat 86 Jan 18th, 2010 1:27 am
Fuel Octane JEC Hall of Wisdom 24 Jun 4th, 2009 3:22 am
Gas experiences? fawkes Supersport 28 Nov 9th, 2007 9:53 pm
