BIGGEST PERFORMANCE BANG FOR THE BUCk!!!!! - Ducati.ms - The Ultimate Ducati Forum
Old Jan 1st, 2008, 7:53 pm   #1 (permalink)
08hyper's Avatar
Talking BIGGEST PERFORMANCE BANG FOR THE BUCk!!!!!
I just finished my airbox mod on my bike and what a DIFFERANCE!!
My seat of the pants dyno says its about 8 to 10 HP, hopefully next week
I'll have the bike on the real dyno and will post the results to see.
The bike is still stock except for this mod, the bike pulls HARDER everywhere!
is SUPER snappy, kinda like Clark Kent when he turns to Superman, well, maybe not that strong (but close!) The bike is sooo much more FUN to ride
and the front wheel will climb in 3rd gear with little effort. The intake now has a
noticeable cool GROWL that lets you something is down there!! Its a good
sound and not annoying. (but it's there!)
As long as your exhaust is STOCK the bike's closed loop ECU will adjust
your fuel map so it won't run overly lean.
I basically did the same airbox mods that (Yota) did, see his post Dec 17,
"airboxmod coupla photos" great pictures Yota, thanks!
I also used the BMC air filter, same as a K&N as far as I can tell,
I used a 2 1/8 in. hole saw for the top air box lid, and I removed the airbox
so I could drill the hole from the bottom of the airbox, (Yota uses a 1 1/2 in. and drills from the top.) I used a 1 3/4 in.
for the bottom hole, its a perfect fit as long as you modifiy the hole saw
by grinding the outside of the cutting teeth to the same size as the OD of the
hole saw body.
Note: the airbox is held in at 3 points, the REAR two points are push ins,
and NOT screws like they look like, just the single front is a small bolt.
I think this is a MUST DO!! mod for any Hyper modified or not, as this will
make your bike run the way it was ment to, a real stealth street fighter!
So after the purchase of the $65 dollar airfilter, a coupla of holes, and a couple of hours you WILL have your "Best Bang for the Buck!"
Now you know, Alex
PS: Compared to the size of the throttle body, the intake hole size of the stock airbox lid is a JOKE! really choked down.......
Old Jan 1st, 2008, 8:57 pm   #2 (permalink)
bromike666's Avatar
Can all us mechanically challenged losers come over to your place and have you mod ours? I'll bring the bourbon!
"I miss the sound of a dry clutch in the morning"
13 Multistrada 1200s Touring
03 749s for the track
bromike666 is offline   Reply With Quote
Old Jan 1st, 2008, 9:02 pm   #3 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
Alex, yesterday you told me the front wheel lofts at will BEFORE you did this mod.
You sir, are a bona fide HOOOOOOOLIGAN!!!
-Marco
Da_Bull is offline   Reply With Quote
Old Jan 1st, 2008, 9:16 pm   #4 (permalink)
08hyper's Avatar
Smile That was 2nd gear!
That was 2nd gear now its 3rd!!
Old Jan 1st, 2008, 10:53 pm   #5 (permalink)
Navigator's Avatar
Should be installing the Leo Vince's later on this week and plan on doing this mod w/ the BMC filter I ordered. OMG its going to get loud and crazy...can't wait to open this thing up! Maybe I'll do it tomorrow before the pipes get in so I'm not overwhelmed with too much as once.
08 Hypermotard
05 CRF-450X Supermoto (CA plated)
01 YZ-426F
Navigator is offline   Reply With Quote
Old Jan 1st, 2008, 11:11 pm   #6 (permalink)
lelenb's Avatar
Images: 12
What ECU do you have? If you have the stocker I don't know if it is a good idea to open up the airbox and install an aftermarket exhaust. I guess you could always plug up the holes if your bike gets lean.
Lelen
Hyper S
Old Jan 1st, 2008, 11:35 pm   #7 (permalink)
08hyper's Avatar
Red face Hic!.....hic!........
Anytime!
Old Jan 1st, 2008, 11:51 pm   #8 (permalink)
Senior Moment
Buckelew's Avatar
I'm still waiting for my friggin' BMC air filter. We're going on a month since I ordered it. I'll be calling tomorrow. grrrrrrrrr.....
Buckelew is offline   Reply With Quote
Old Jan 1st, 2008, 11:52 pm   #9 (permalink)
Senior Moment
Buckelew's Avatar
expect to see 4hp.
Old Jan 1st, 2008, 11:57 pm   #10 (permalink)
hyprduc's Avatar
Did you do the mod the second you got home from the ride??!!I ordered a DP airbox cover for $21 rather than cut up the stock one. I guess I should order the BMC filter too. I'll put new tires on this weekend during the rain, then my Hyper is off to Zero Gravity to finish up a windscreen. I'll post pics when I get it back.
Cheers and Happy New Year to all!
hyprduc is offline   Reply With Quote
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 6 Dec 18th, 2012 6:04 am
Best bang for the buck exhaust for 800SS? suba007 Supersport 15 Oct 24th, 2007 12:31 pm
Best bang for the buck: Wheels or Suspension? synfinatic Superbikes 57 Oct 10th, 2007 1:19 pm
Bang for the buck exhaust vmuth Superbikes 1 Jun 17th, 2006 10:56 am
More bang for my buck with new exhaust for 999R? lastblast Superbikes 2 Jun 6th, 2006 5:25 pm
