Originally Posted by mbohn
Any pricing info yet? It looks like the S model only differs from the base model by the Ohlins shock. Wonder why they didn't do an Ohlins fork too.
Cool bike, tho.
WHEN TOO MUCH IS WHAT YOU NEED - 2008 MODEL EARLY RELEASE
Adding ‘S’ to the Hypermotard takes the thrills and road holding to the highest level.
The outstanding Marzocchi 50mm forks of the ‘S’
include a durable low friction, DLC (diamond-like carbon) black coating to the sliders, making the Hypermotard ‘S’ respond effortlessly to every minute variation in the tarmac and improve its already impressive road holding. The advanced ‘S’ suspension is further enhanced with an
Öhlins remote reservoir rear shock, renowned in racing circles as the ultimate performance choice. This incredible shock is fully adjustable for compression and rebound damping and spring preload ensuring that the ‘S’ is readily adaptable to riding style and every road it challenges.
With a bike as capable as the Hypermotard 1100 S, superior stopping power is fundamental. By using the same
Brembo Monobloc calipers first introduced to the world on our new 1098 Superbike, world class braking performance is assured. Each caliper is created from a single casting, as compared to the conventional two piece construction, to ensure rigid flex-free operation and a consistent solid ‘feel’ at the lever. And to ensure that the look of the calipers matches the ‘S’ personality, each is machine finished.
Professional racers know that one of the best ways to improve the handling and performance of a motorcycle is to reduce unsprung weight by upgrading to superior lightweight wheels. Even from a distance, the black Marchesini wheels with red pin-stripe confirm the ‘S’ performance of this Hypermotard. Created from
forged then machined alloy, both front and rear wheels are significantly lighter and create a lower moment of inertia and unsprung weight for improved handling and quicker steering. Mounted to the wheels are new Z-rated
Pirelli Diablo Corsa III tyres. Designed to deliver racing performance on the road, they warm up quickly, give great feedback, are stable under severe braking and feature dual compound construction on the rear.
The ‘S’ lightweight performance and extreme look is further enhanced with the liberal use of
carbon fibre. The advanced composite is used for the fork protectors, timing belt covers, front fender rear section and tail side covers.
The Hypermotard ‘S’—maximum performance, minimum weight, extreme attitude.
2008 MSRP $13,995 USD ($17,995 CND)
1100 base model is $11,495 USD
