Feb 22nd, 2012, 1:52 am
#21 (permalink)
I didn't like em. Actually that's not fair, I did like the light weight, stick, ease of turn in, etc... Pushed a little too far I guess and it just broke without warning. I must want/need a little more progression towards the point of no return. Never was fully comfortable on them.
Bryce
current duc... 08 hyper 1100
Feb 22nd, 2012, 2:52 am
#22 (permalink)
Flavor of the Month
2CT means dual compound. There are Pilot Powers, Pilot Powers 2CT, Power Pure 2CTs and Power One 2CT. Between the three 2CT models the difference is not just the tread pattern, but also how the dual compounds are arranged.
I've ran the Pures on both my bikes on the street and track and Power Ones on my 748 at the track, but not the DOT type. They seam to do ok for me, but I'm only a C group guy (for now...).
Sam 'MF' Brandt
2000 Ducati 748
2006 Yamaha YZ450F (SCARY!)
2008 Suzuki DRZ-70 pit bike
2008 Ducati HyperMotard S
Feb 22nd, 2012, 5:43 am
#23 (permalink)
Originally Posted by 08hyper
Actually they were the 2CT's, HATE them now, but did here good things the lightweight "pures" though, or do they act like the 2CT's? Aloha Alex
I hate 2ct's as well, they behave weird. Normal Pilot Powers however are just fine.
Feb 22nd, 2012, 9:29 am
#24 (permalink)
Originally Posted by Ben710
word dude.
Cosmic: what are your current settings? Did you measure sag?
great question. i don't know current settings
i am 175 lbs and willing to take anyones suggestions. on track bike feels very planted and comfortable. on street its another story.
Feb 22nd, 2012, 11:56 am
#25 (permalink)
ohlins carts/revalved rear ohlins and rosso corsas
Feb 22nd, 2012, 12:39 pm
#26 (permalink)
Flavor of the Month
How come you re-valved the shock? If my forks getting serviced doesn't make help at all with my handling issues I was thinking about getting the shock worked on along with a cartridge kit...is the shock set up for heavy dudes? I'm only 180lbs.
Sam 'MF' Brandt
2000 Ducati 748
Feb 22nd, 2012, 4:36 pm
#27 (permalink)
with gear im about 185 to 190 with backback and all...when i had ohlins do my forks they said send in the rear as well and they could make it perform a 100% better due to ducati cutting corners on some of the componets inside the shock to save money it now performs like my ttx s on my other two bikes...
Feb 23rd, 2012, 10:49 am
#28 (permalink)
I just had my rear Ohlins shock rebuilt/serviced, cleaned out, new seals, new Ohlins shock fluid, inspected. He is a Ohlins distributer & told me the shock was fine, he did notice that I was near the end of my adjustment range, so he removed a couple of shims for me so I would be in the "middle" of my adjustment range. I guess that's what you call revalving.
The good news is the suspension guy said our shoock is as good as the one you can buy from Ohlins, (no cheap parts) the only difference being the Ducati spec valving. Aloha Alex
Feb 23rd, 2012, 11:16 am
#29 (permalink)
acually looking at the paperwork last night my forks went to ohlins and the shock was redone by dan kyle spring,valving,adj and aluminum adj nut..replacing plastic one....?
Feb 23rd, 2012, 2:09 pm
#30 (permalink)
[QUOTE=disgo duc;1284992]acually looking at the paperwork last night my forks went to ohlins and the shock was redone by dan kyle spring,valving,adj and aluminum adj nut..replacing plastic one....?[/QUOTE ]
The plastic shock spring nut was a Ducati spec, it was supposed to make the spring adjustment easier, & did cause some shock body problems for some, you can get a aluminum shock nut part #531-01 direct from Ohlins for about $20. Aloha Alex
