Mine reads.....
01092-29/90 L447
The -29 is the spring rate. For some unknown reason Ohlins uses it’s own numbers to label rate. In this case a -29 is a 90nm or 9.17kg or 514lb spring
The /90 is the springs rate in Newton millimeters. In this case the /90 means it’s a 90 N/mm spring.
1092 is 6.7" in length.
Now....all that said.....what do I have and what do I need??
