Turn Signal Indicator Issue - Page 2 - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!SportbikeTrackGearGraves MotorsportsMotorcycle.com
Old Feb 19th, 2012, 2:57 pm   #11 (permalink)
Secret Squirrel's Avatar
I found this thread. This could be a resistance issue according to this owner. Here's the link.
Dash Turn Indicator Not Working
2011 Ducati Streetfighter S
2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
1996 Suzuki GSXR-1100-Sold
2001 Suzuki TL1000R-Sold
Secret Squirrel is online now   Reply With Quote
Old Feb 19th, 2012, 3:14 pm   #12 (permalink)
James998FE's Avatar
Thanks, that could be it. Guess I'll have to do some research on resistors and see what type, style, size I need and where to put them.
2004 998sFE
2008 Hypermotard 1100s
More to come someday...
James998FE is offline   Reply With Quote
Old Feb 19th, 2012, 5:36 pm   #13 (permalink)
Thermal Runaway's Avatar
I vote resistance issue as well. Three combinations that I tried. LED front and LED rear turns, stock brake = normal flash but no dash indicator. LED front and LED integrated rear = fast flash, dash indicator works. LED front, LED integrated rear + resistors = normal flash speed and dash indicator works .
see the following for electrical info:
Electrical Tech Heads- Help Work This Out.
Blinker Idicator on Dash Not Working
Turn signal dummy light stopped working?
Bryce
current duc... 08 hyper 1100
Thermal Runaway is offline   Reply With Quote
Old Feb 20th, 2012, 8:33 am   #14 (permalink)
James998FE's Avatar
UPDATE:
Ok so I got some resistors yesterday 10w10ohm and 10w50ohm cause thats all they had and I slaved in the 10w10ohm and the dash indicator came back but it and the turn signals flashed fast. The 10w50ohm was TOO much resistance so that didn't work. I also went back and forth with the Service menu settings "lamp" or "led" and could not get the flash rate and dash indicator to work as it should. I tried every possible combination with the 10w10ohm resistors and service menu. I am so confused now.
2004 998sFE
Old Feb 20th, 2012, 9:49 am   #15 (permalink)
If the 10 ohm worked barely but the 50 ohm was too fast, then it sounds like somewhere between those two is what you need. You can also combine resistors to come up with different values if you wire them in series.
Another option would be to have someone measure the resistance on the stock setup, compare with what your signals are and use the proper resistors to get the correct values.
You could try these Oberon ones from Motowheels. They wire in parallel.
OBERON LED Indicator Resistors
mia748sp is offline   Reply With Quote
Old Feb 20th, 2012, 1:08 pm   #16 (permalink)
For what it's worth I am not sure that changing from lamp to led in the menu ever actually did anything, at least on my 08.
Bryce
Old Feb 20th, 2012, 2:00 pm   #17 (permalink)
James998FE's Avatar
Slaving in the stock rear in some form or combination I was able to see a difference with the LAMP/LED settings but overall I still have not got the desired result. I'm going to see if I can find a 10w20 or 22 ohm resistor.
2004 998sFE
Old Feb 21st, 2012, 8:40 pm   #18 (permalink)
Mr Mike's Avatar
Where and how are you putting the resistors ?
Stock uses LED fronts and Bulbs in rear.
If you have all LED then you need the resistors parrallel to the REAR LEDs
? CUSHMAN GOLDEN EAGLE
Old Feb 21st, 2012, 8:54 pm   #19 (permalink)
James998FE's Avatar
The resistors were slaved in parallel on the rear lights, one on each side.
2004 998sFE
Fs: 4 turn signal mini indicator ducati 748 749 996 998 riva996 Parts and Accessories 0 Feb 17th, 2012 5:55 pm
turn signal indicator light question goyaohboyajr Supersport 6 Mar 31st, 2008 8:43 am
Alright so my turn signal issue is fixed... KoiHoshi Supersport 4 Jul 21st, 2007 2:31 pm
Dash Board Turn Signal Indicator Light ST4s 2UpDuc Sport Touring 1 Apr 28th, 2006 1:48 pm
Clear Turn Signal Indicator Question BHakaLaw Superbikes 12 Apr 26th, 2006 9:10 pm
