I don't even have one - but it is on order. I do have a bit of old inner tube tie-wrapped to various points - sure is ugly
, but it keeps muck off the shock & out of the lower shock mount. The only issue with the various shock sox is how close the
796 spring is to the exhaust - looks like not enough room to fit one without melting it. don't know 'bout the 1100's.
I have measured up to fit an ally panel under the seat area too, there is exposed wiring vulnerable to stones flicked off the tyre. Figure it might keep the rear in better shape when I fit it.
You could rivet a plate straight up off the top of the hugger to catch more spray. might look a bit
tho'!
Have you seen the size of Rossi n Hayden's huggers? Hayuge!
Can't avoid the rain here.
