Charcoal canister - Ducati.ms - The Ultimate Ducati Forum
Old Feb 18th, 2012, 2:05 am   #1 (permalink)
vb796's Avatar
Charcoal canister
What's the actual purpose of this thing? I know it has to with emissions but that's all I know. I took it off ,plugged the hose going to the "tee" fitting that routes to each intake duct . Then just ran the fuel tank vent down to bottom near oil cooler lines
vb796 is offline   Reply With Quote
Old Feb 18th, 2012, 4:42 am   #2 (permalink)
beelzebob's Avatar
It filters fuel vapors thru the charcoal canister taking away any gas smell and re introduces them into the intake tract.With mine removed after a ride my garage smells like Sunoco premium , wife hates it . I like it , you can make a nicer job of it by removing the lines to the intakes and putting the "right sized"(not too long)metric screws in there instead of the hose fittings. I also inserted a plastic end in the main vent (largest line) just to decrease the size but still let it breath,with that the fumes don't seem to roll out as bad.
beelzebob is online now   Reply With Quote
Old Feb 21st, 2012, 8:28 pm   #3 (permalink)
Mr Mike's Avatar
I did the remove EVERYTHING and plug/cap the intakes but during my last service the Mechanic recommended connecting a single vac line from one intake to the other. Said it would help balance the intakes. I know this works on transverse 4 cyl bikes (1-4 , 2-3).
Makes sense.
? CUSHMAN GOLDEN EAGLE
Old Feb 21st, 2012, 8:31 pm   #4 (permalink)
vb796's Avatar
I plugged the one line that goes into the "T" fitting that goes to each intake . Wouldn't that be the same thing ?
Old Feb 21st, 2012, 8:41 pm   #5 (permalink)
Mr Mike's Avatar
Originally Posted by jjernigan1 View Post
i plugged the one line that goes into the "t" fitting that goes to each intake . Wouldn't that be the same thing ?
yes
Old Feb 21st, 2012, 8:59 pm   #6 (permalink)
vb796's Avatar
I haven't notice any fuel smell after rides yet. Sounds like an overfill tank problem . Splashing down the overflow tube
Old Feb 22nd, 2012, 12:00 pm   #7 (permalink)
disgo duc's Avatar
Images: 23
bbq that fvcker!
Old Feb 22nd, 2012, 12:12 pm   #8 (permalink)
+1
2008 Hypermotard S
2010 Multistrada S Touring
2009 BMW R1200 GS
Willie B is offline   Reply With Quote
Charcoal Canister Removal 999s Superbikes 3 Aug 4th, 2011 3:17 pm
Removing a charcoal canister from 748 Dmitry Superbikes 6 Feb 4th, 2011 12:03 pm
Charcoal Canister... DUCATIHIBBZ Monster 15 Sep 15th, 2009 10:46 am
696 charcoal canister motorhead748 Monster 1 Mar 25th, 2009 7:05 am
Charcoal Canister SP544 HyperMotard 25 Jul 26th, 2008 10:53 am
