oil cooler - Ducati.ms - The Ultimate Ducati Forum
Old Feb 16th, 2012, 5:39 am   #1 (permalink)
oil cooler
did a search and couldn't find too much on it in relation to hypers..
anyone install an aftermarket oil cooler on their 1100?
Ducati Hypermotard Oil Cooler By SC-Project
haven't checked the NCR website yet but do they make one for the hyper?
if you've installed it on your bike WHY and WHEN did you consider installing it? In other words, if you replaced the cylinders was that the point where you said, 'i should probably increase the cooling'?
I'm not going to replace internals but I will be increasing the power via bolt ons and a dyno tune and in an effort to keep the motor cool and efficient i figured i should upgrade the oil cooler..
thoughts appreciated.
mypetmonster is offline   Reply With Quote
Old Feb 16th, 2012, 5:41 am   #2 (permalink)
johnnie27's Avatar
you could always try to find a used one from a evo or evo sp..the are bigger
Old Feb 16th, 2012, 10:23 am   #3 (permalink)
mental999's Avatar
The SC Project oil cooler is probably the most effective mod you can do to the Hyper. I love mine. Got it from Motovation.
mental999 is offline   Reply With Quote
Old Feb 16th, 2012, 10:27 am   #4 (permalink)
Official Sponsor
desmoworks's Avatar
I have the NCR for my 2V. I've used it on a couple of bikes - it works great.
NCR Ducati Oversize Oil Cooler Kit for 1000 and 1100 DS Motors (NCR.04.00.011) | Pro Italia
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old Feb 16th, 2012, 10:57 am   #5 (permalink)
08hyper's Avatar
I use the Febur one, its oversized, curved, & aluminum, works great.
The NCR one is good but it does not have the oil temp fitting like the stock or Febur one.
I think anyone that has a modded motor, runs their aircooled motors hard or lives in a hot climate will be beter off with one. I personally would not run without one. Aloha Alex
Old Feb 16th, 2012, 12:24 pm   #6 (permalink)
Alex, Where did you find the Febur oil cooler for your H-Tard? I looked at their website and wasn't able to find it. Is there a stockist in the US?
2008 Hypermotard S
2010 Multistrada S Touring
2009 BMW R1200 GS
Willie B is offline   Reply With Quote
Old Feb 16th, 2012, 1:21 pm   #7 (permalink)
minusone's Avatar
After seeing some high temps in summer traffic I installed the febur unit.
No problems, works great and I don't get notchy gear changes asociated with hot thinning oil.
I think I ordered direct from Italy
[ Current Rides ]
Gas Gas Raga Replica
Husky TE450
KTM 690 Enduro Rally Raid
Hypermotard 1100S
Multistrada 1200S
Old Feb 16th, 2012, 3:55 pm   #8 (permalink)
thanks for the responses y'all... i have the evo SP and just wanted to make sure when i bump the power the cooling is there also
Old Feb 16th, 2012, 4:26 pm   #9 (permalink)
johnnie27's Avatar
FYI you know the evo and sp already have a big one right
A new oil cooler with 85 percent more surface area keeps internal temps for the air-cooled engine under control, while the old unit finds its way down to the 796.
Old Feb 16th, 2012, 4:56 pm   #10 (permalink)
this is still engineered for the stock motor, producing factory numbers... correct? when i mod the motor and bump the power i'm gonna want to have better cooling, ya?
anything else i need for the oil cooler? sweetjeep94 Superbikes 0 Aug 17th, 2010 4:05 pm
696 oil cooler be350ka Monster 7 Nov 6th, 2008 11:13 pm
Oil cooler Ducatibomber Sport Classic 3 Aug 24th, 2008 1:36 pm
Oil cooler gone bad....? 72sshunter Superbikes 2 Jan 11th, 2007 4:08 pm
WTB: Oil Cooler Synergy Superbikes 1 Feb 23rd, 2006 2:59 pm
