Advice Please (injector) - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jan 31st, 2012, 10:18 am   #1 (permalink)
sumondabitches's Avatar
Got an error code 13.2 Vertical Cylinder Injector after removing PC3.. sure enough I had damaged the injector. OEM part 280.4.015.1A is over $300. Are there cheaper alternitives? Thanks.
sumondabitches is offline   Reply With Quote
Old Jan 31st, 2012, 1:24 pm   #2 (permalink)
poakone's Avatar
Ebay! I've seen entire throttle body sets injectors and all on there for 100.00ish. Like this one.
DUCATI HYPERMOTARD 1100/1100S THROTTLE BODIES BODY INJECTORS | eBay
I've been thinking pretty hard about buying a set and having them rifle bored to see if it would increase power any. If I gained a single horse it would still be a relatively affordable mod. Seeing as how much an exhaust costs to gain 5-10 ponies.....
In fact if you go this route pm me I'd be willing to give ya 60.00is for the throttle bodies with out the injectors......
L8r Kone
2010 Hyper 1100 Evo.
2002 Suzuki Rm265 too many mods to list
2002 Arctic Cat M8 151"x14"2.25"
2008 KingQuad 450 Axi "Mini Jeep"
poakone is online now   Reply With Quote
Old Jan 31st, 2012, 1:46 pm   #3 (permalink)
Nice find! I live on the Greek island of Rhodes so it doesnt make sense for me to get the whole thing shipped here when all I need is one small injector and then ship the majority back over to you.... MAYBE you could order it and send me an injector for 60 bucks
Old Jan 31st, 2012, 2:14 pm   #4 (permalink)
poakone's Avatar
Let me check with my financial adviser (wife) but I think this is a win,win. situation. If I get the aproval I'd even sell you both injectors for 60.00, just incase one of the used ones is screwed up. I'll get back to you shortly and let you know.
L8r Kone
Old Jan 31st, 2012, 2:34 pm   #5 (permalink)
Coolio
Old Jan 31st, 2012, 3:09 pm   #6 (permalink)
Extended Member
CAlexio's Avatar
Person to person commerce rationalizes prices and makes for a fluid parts market without intermediaries.,, Im amazed at this new internet thingy they came up with... Hopefullynits not just a passing trend
Old Jan 31st, 2012, 8:38 pm   #7 (permalink)
Akasam's Avatar
LOL
2010 Hypermotard 1100evo
Re-flash, PCV, AutoTune, MWR Lid, LV Decat, Fresco Exhaust, Ohlins Steering dampener,
Exhaust
http://youtu.be/F7O6h4i9jFo
Awesomeness
http://youtu.be/QELv_MCBG3c
Akasam is offline   Reply With Quote
Old Feb 1st, 2012, 1:50 am   #8 (permalink)
poakone's Avatar
Sorry but the injectors you need and the throttle bodies I need aren't the same, I got 2010 and my injectors won't fit into the throttle bodies the injectors you need would come out of. So it looks like we both are stuck for more moneys. I would tell you though buy the throttle bodies off of ebay get the injector you need and shelf the rest or toss it you can still get 2 injectors for 1/3 the cost of one new one. sorry the 50-50 thing won't work but if i get tb's for an 08 I need the injectors too. and if I get Tb's for '10 the injectors won't work for you.
On other good news i did get the better halfs ok to proceed with purchasing a set of throttle bodies and sending them out to be rifle bored. with total cost of up to 500.00. So I'm now looking into a set of TB's for a 2010 then I got extra injectors too.
L8r Kone
Old Feb 1st, 2012, 5:47 am   #9 (permalink)
OK Bro, Thanks for trying. good luck with your project.
Old Feb 1st, 2012, 8:16 am   #10 (permalink)
Update
May not bo e an injector after all... just to make sure i switched them around and hooked the batery back up, turned on the ignition and cycled the error codes... still showing 13.2 vertical cylinder injector... then I removed both injectors from the harness and checked the error codes which should indicate problems with both the vertical and horizontal, but still only 13.2
any ideas?
fuel injector SPS johnnie27 Superbikes 21 Feb 3rd, 2011 5:11 am
996 Injector erniebu Superbikes 3 Feb 7th, 2009 9:47 pm
Injector cleaning danrduc Sport Touring 2 Feb 6th, 2009 5:33 pm
Ever had a stuck injector? greggkirby Ducati Motorcycle Chat 16 Jan 18th, 2009 10:42 am
996 single injector mod? mcdunna77 Superbikes 2 May 10th, 2006 10:04 pm
