Jan 31st, 2012, 7:16 am
PVC install ?
Just received my PVC with optimizer and before I begin I'm curious is this thing plug and play or is there any splicing involved? It's a 2012 stock 796
Jan 31st, 2012, 7:20 am
I finished installation tonight. It is basically pnp, except one orange throttle wire. But it is easy. Just the injector plugs took me 30 mins to figure how to unplug them.
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
Jan 31st, 2012, 7:33 am
How's the results ?
Jan 31st, 2012, 1:14 pm
With you there what Pain in the ass! It took me a little more time than that but I'm really picky about wire runs, mounting equipment, etc. Also had Auto tune, and the lcd200 display to put in. I probably spent more time though finding the engine temp sensor and speed wire so I could have those inputs on the PcV monitored as well. But the biggest Time killer was finding the best spots to place the two additional Exhaust sensors for the auto tune.
O2 for auto tune on vertical cylinder (looking down from top)
O2 for horizontal cylinder looking over LV cat eliminator. (a little carbon fiber saw dust on decat from trimming hugger fender for decat fitment)
and from side factory o2 is the one closest to you
L8r Kone
2010 Hyper 1100 Evo.
2002 Suzuki Rm265 too many mods to list
2002 Arctic Cat M8 151"x14"2.25"
2008 KingQuad 450 Axi "Mini Jeep"
Jan 31st, 2012, 6:19 pm
How's the results ?
I loaded the all stock map and still have surge at low end under 3000rpm. But it seems a little bit better. And feel the acceleration is lazier as before. I am seeking a custom map or I will do a dyno as the last resort
Stock handle bar
Stock shock
Feb 1st, 2012, 6:53 pm
Sounds like you either do not have the stock exhaust and you are using the stock map...or the Optimizer box isn't installed. If in fact you are running a STOCK bike with a STOCK map and Optimizer box....then you shouldn't be feeling any surging except at about 1800 to 2k revs. Ducati's don't run smooth under 2k...no matter what you do. The Throttle bodies are too large in diameter.
Feb 4th, 2012, 6:19 pm
Hey guys, any word on pcv compatibility with 2010's, 11's and 12's? All the same part/connectors, or is there any difference?
apparently, the guys at my local shop spoke with dynojet, and dynojet was unsure if the fitment is the same
whats the part number on the PCV and optimizer for the 2012 hyper 796?
i have a 2011, and im trying to pick one up
Feb 4th, 2012, 6:41 pm
I talked to my duc dealer and they told me the plug in port is the same on the Siemens ecu's on 2010,11,12 . They also told me the for$300 they can dyno tune my 796 making a custom map for my bike and make it a full open loop and results will be way better than pcv guaranteed !!! .... Power commander going back !!!
Feb 4th, 2012, 7:41 pm
I'm very curious about this. If you go that route, please post results, Dyno chart, etc.
I'm just a little skeptical, because I have come across too many authorized Ducati 'experts'. Many of whom didn't have a clue!
Feb 4th, 2012, 8:01 pm
I will post results . My info came from redline performance in Yorktown ,va. Contact Dave ( the president of redline performance) he's suppose to be the Ducati scientist !!
