Originally Posted by zakwan
Not sure what you mean. The bolts are the original bolts that came with the kit, the nuts are stainless and stronger than original threaded brakets that came with the kit, the washers and nylon spacers are beefier than supplied. The modes I made is to make it fit properly and actually make it stronger. The set up I used on the hyper is better and stronger than the standard set up on my tiger 800. Time will tell. I ride all year around, if it breaks I'll let you know
I don't think anyone has any issues with the bolts. It looks like that cheap cast aluminum rack is the problem. You could bolt it down with titanium, but it's still going to fall off when that tongue breaks...
Maybe I'm misunderstanding this part..
