Jan 19th, 2012, 5:27 am
Marzocchi forks manual?
Does anyone have a PDF manual of our 2008 base model Marzocchi forks? I am not sure about the actual product name. I suppose they are called Marzocchi Tenneco 45?
Jan 19th, 2012, 9:43 am
I was just about to post a similar topic. I am about to change the springs on my stock 2010 evo and I was hoping that someone would be able to get me the section of the service manual for the forks.
Sent from my Motorcycle iPad app
Jan 19th, 2012, 10:03 am
Extended Member
Me three for same reason as above
Jan 19th, 2012, 11:21 am
Originally Posted by Frustration
Try this. Aloha Alex
Jan 19th, 2012, 12:03 pm
Extended Member
The hyper Hawaiian strikes again. Thank you .
Jan 19th, 2012, 12:15 pm
Let me guess it probably would read someting like:
We would like to thank you for buying Marzzocchi forks. bla bla bla and some bad translations.....
To bad for you that you have bought the S version, which are as crappy as the non S version. bla bla bla
Remove forks from bike remove top cap, ditch internals and go shop around if you are over 100lbs?
I'll bet I am not far off, am I?
A.K.A Floris748
HM1100S 2007
Tuned by Biggelaar Performance 108.6Hp@ 7390rpm / 113Nm@ 4081rpm
Zard full header, 2-2 Termi slip-on, Lightened stock fly wheel (700gr), DP cams, DP ECU (reflashed), DP airbox lid, K&N filter, Hyperpro modified front fork, EVR pressure plate, EVR open clutch cover, Evotech crash protectors, Evotech tail tidy...
Jan 19th, 2012, 1:34 pm
Now if some one could make that same web page for the new hypers. I did find the instrument panel page very useful though. When I got my ECU back from re-flash it said EU and everything was in Kilometers but the Display options are almost the same so I was able to go in and change it back to USA.
Jan 19th, 2012, 4:06 pm
I took mine apart today, so just in case you guys have questions, feel free to ask.
Jan 19th, 2012, 6:18 pm
Is there any oil in them there forks?  Aloha Alex
Jan 19th, 2012, 8:07 pm
What was the exact measurement of oil that you put back in?
