14T Sprocket - Ducati.ms - The Ultimate Ducati Forum
Old Jan 18th, 2012, 2:25 pm   #1 (permalink)
Location: Northern, , Ireland (Ducati Hypermotard 2012 evo corse 1100)
14T Sprocket
What are the benifits of a 14t sprocket on a 1100 evo hyper guys
"ye must be born again" John 3 v 7
Darsey is offline   Reply With Quote
Old Jan 18th, 2012, 2:32 pm   #2 (permalink)
Old Fast Guy
TOP_DUC's Avatar
More wheelie FUN...! Plus quicker accleration, smoother low rpm response. I have a 190/55 rear tire and it runs ~65 mph @ 4k rpms. Right in the meat of the power band so it will accelerate like a rocket from there. Top speed is ~133 mph, drag limited fully tucked. Could be faster without winter gear flapping in the breeze though...
`11 1198SP SBK Red; w/Termi exh; Redline flash + PC-5 tune; Sargent; Shift-tech, EVR(airbox), CDT, & BST(wheels) carbon; FBF 14/39 QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf... 170whp/98wtq
`12 1100SP EVO Hyper CORSE; w/Termi exh; Ducshop Stacks; Redline flash + PC-5 tune; FBF 14/41 QC; Shift-tech, CDT, Star, & BST(wheels) carbon; R&G; SF bars; ProGrip; Antigravity; SC Project; Ducabike; Duc Perf slipper; screen, str damper, seat, cat delete... 95whp/75wtq
TOP_DUC is offline   Reply With Quote
Old Jan 18th, 2012, 3:00 pm   #3 (permalink)
Drinky's Avatar
Images: 3
Downsides: more wear on the chain, slapping against swingarm, adverse effects on suspension.
It would be better to go up 2 or 3 teeth at the rear, but that's a bit more expensive than changing the front sprocket.
@ Top Duc
I've had a 190 rear, and it really sucked. Not only did it give me LESS grip, it also turned in much slower than my current 180 rear. It did look cooler though
Old Jan 18th, 2012, 3:15 pm   #4 (permalink)
Old Fast Guy
TOP_DUC's Avatar
I haven't had any problems with the 190 tire...? I've run it right out to the edge and had some chattering under hard braking, but the slipper clutch corrected that. I have had the tire slide a bit on corner exit with WOT, but turn-in and mid-corner feel are fine. I expect the tire construction/rubber compound has more to do with the "feel" than the slight size difference... YMMV
Oh, and there is no chain slapping or adverse suspension reactions either. I tend to suspect a placebo effect from the power of suggestion may be a factor in the 14T front is "bad" reports. The facts are that a 14T front runs a slightly smaller radius and if I were running at Bonneville for a speed record, I would run as large diameter sprockets as I could fit to reduce that microscopically measured radius drag, but for any other purpose, the 14T is a no-brainer to help the big twins attitude at lower speeds...
Old Jan 18th, 2012, 8:10 pm   #5 (permalink)
vb796's Avatar
I have a 796, love the 14t front !! Way smoother in traffic and slower speeds . No swing arm slapping noticed yet.
vb796 is offline   Reply With Quote
Old Jan 18th, 2012, 9:17 pm   #6 (permalink)
Properly adjusted chain = no chain slapping. True story.
HyperDuc796 is offline   Reply With Quote
Old Jan 18th, 2012, 9:40 pm   #7 (permalink)
I put a 44 rear instead. but the low end problem is still there below 3000 rpm
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
nethern is offline   Reply With Quote
Old Jan 18th, 2012, 9:50 pm   #8 (permalink)
Old Fast Guy
TOP_DUC's Avatar
I have TWO Ducatis that so MANY people have said run like crap and have all kinds of problems at low rpms even after making the recommended changes, yet I don't seem to have any of those problems. Maybe finer throttle control is the answer...?
Old Jan 18th, 2012, 11:00 pm   #9 (permalink)
Supersprox 15f 43r 520 conversion on mine...love'n it. Essentially the same as dropping one tooth in the front but I wanted less sprung weight by going to a smaller chain, plus I got a cooler looking rear sprocket and gold chain....looks AND performance....yes please!
2009 Ducati 1198S (Red)
2011 Ducati Hypermotard EVO SP (White)
djauman is offline   Reply With Quote
Old Jan 20th, 2012, 1:24 am   #10 (permalink)
nickd64's Avatar
@ Top Duc
Drinks, have to disagree. I have modified and run 14 tooth front sprockets on all my 2v Ducatis. With the Hypermotard on 14/42 525 presently. I've never suffered slapping or adverse suspension effects. If fact in my part of the world this is considered a pretty standard modification. Although I do concur on the 190 rear tyre. Don't see any benefit from increasing the the diameter. 180 is optimal IMO.
Nick - 2008 Hypermotard S
nickd64 is offline   Reply With Quote
Sprocket set Gramps Supersport 11 Jan 22nd, 2011 5:06 am
Need helpful ideas to remove sprocket 916 sprocket carrier nut duc995 Superbikes 18 Jul 24th, 2010 8:51 am
Sprocket help Trenman Superbikes 6 Jan 9th, 2009 11:38 pm
What Sprocket is this? xplodee Sport Classic 2 Oct 15th, 2007 9:17 pm
Sprocket Specialists front sprocket cachee0 Superbikes 4 Oct 19th, 2006 6:57 am
