PCV+?? (Autotune or a dyno run) - Ducati.ms - The Ultimate Ducati Forum
Old Jan 16th, 2012, 8:05 pm   #1 (permalink)
I have put a 15+44 sprocket setup on my 796, and it now runs better, but the low end surge is still there. After being able to locate a local shop that does dyno with PCV, i got a quote of > $950 (dyno + PCV + PCV install).
I have heard autotune can automatically adjust some a/f ratio to remove the low end problem, which might save the money of going dyno whenever i have a mode. Haing read the thread AutoTune installed on my 796, I feel challenge about installing that although I am a bit handy. Plus, the autotune is not cheap too $450.
So, my decision is which way to go?
1. PCV + dyno run ($950) + potential more dyno run in the future $$
2. PCV + autotune ($920) + mess around with installations
PS: is autotune really that good? The statement stays true? - "it would take 20 dyno runs and a good tuner to even come close to what the Autotune does"
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
nethern is offline   Reply With Quote
Old Jan 16th, 2012, 8:56 pm   #2 (permalink)
Old Fast Guy
TOP_DUC's Avatar
The autotune is pretty good for a mild street tune and somewhat improved driveability, but you need a load dyno that can load the tire to hold the rpms at the set points to allow time for the dyno/ECU software to show the actual AFR for accurate WOT tuning. FYI, the Dynojet dyno basically employs the autotune software function, except the operator can set the throttle and rpms accurately where on the street autotune there is simply no way you can keep the throttle and rpms at the set points long enough to allow truely accurate readings. I recommend the full dyno tune for best results...
`11 1198SP SBK Red; w/Termi exh; Redline flash + PC-5 tune; Sargent; Shift-tech, EVR(airbox), CDT, & BST(wheels) carbon; FBF 14/39 QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf... 170whp/98wtq
`12 1100SP EVO Hyper CORSE; w/Termi exh; Ducshop Stacks; Redline flash + PC-5 tune; FBF 14/41 QC; Shift-tech, CDT, Star, & BST(wheels) carbon; R&G; SF bars; ProGrip; Antigravity; SC Project; Ducabike; Duc Perf slipper; screen, str damper, seat, cat delete... 95whp/75wtq
TOP_DUC is offline   Reply With Quote
Old Jan 16th, 2012, 10:40 pm   #3 (permalink)
thirteenoNYC's Avatar
the super low budget option being purchase and install the power commander yourself, and search the web for a custom map someone has made with similar specs as yours (full exhaust system, just a slip on, similar model year, etc. etc.) install the map and you're good to go. Its no custom tuning, but it may tide you over till you decide which option suits you
ps, custom maps are widely available and a quick search may even steer you to a map identical to your setup
thirteenoNYC is online now   Reply With Quote
Old Jan 16th, 2012, 11:20 pm   #4 (permalink)
My bike is around 2200KM now. Is it suitable for a dyno run? In the manual, it is not recommended to exceed 7500rpm?
Stock handle bar
Stock shock
Old Jan 17th, 2012, 6:38 am   #5 (permalink)
Old Fast Guy
TOP_DUC's Avatar
The bike should be fine. I have the rev limiter set to 9800 rpm on my 1100SP.
Old Jan 17th, 2012, 8:32 am   #6 (permalink)
ccemn1's Avatar
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
ccemn1 is offline   Reply With Quote
Old Jan 17th, 2012, 6:35 pm   #7 (permalink)
Wow, that is news for me. So I should run it as hard as I can then.
Stock handle bar
Stock shock
Old Jan 17th, 2012, 7:37 pm   #8 (permalink)
ccemn1's Avatar
Most racers & tuners I know do!
I had a Porsche Speedster that I put a brand new motor in. Because it was a high end item, I babied the motor like you would according to any manufacturers break-in procedures.
The rings never seated on the damn thing. It still smokes, 20 years later!
Old Jan 17th, 2012, 7:46 pm   #9 (permalink)
ccemn1's Avatar
I think most importantly, run the engine fairly hard, but vary the RPM's a lot, up & down. Then, change the oil & filter at about 50 miles, then again at about 200. Maybe once more at 1200, or 1300, before going to regular scheduled changes. In the very beginning, when everything is 'seating in', there's a lot of junk coming off the rings, cylinders, bearings, valves & seats, etc. It's important to keep from recycling that through your motor. Running hard, frequent, early oil & filter changes will make everything wear in & seat really good!
Mobil One, or any high quality, fully synthetic oil is a must also!
Old Jan 30th, 2012, 2:10 pm   #10 (permalink)
I was with you until this last line! Synthetic oil's just TOO good for running an engine in - it's so effective at reducing wear that it simply prevents bedding in.
If you used synthetic when breaking in the Porsche, it would certainly explain the issue you've had...
Regards
Rob
Peak District
UK
vulpine3 is offline   Reply With Quote
AutoTune installed on my 796 Seven9Six HyperMotard 35 Jan 22nd, 2012 1:06 am
PCV with Autotune on a MTS 1200. mitsu Multistrada 1 Jan 5th, 2012 12:16 pm
Wtb or rent microtec m163 autotune alex1098 Parts and Accessories 0 Feb 3rd, 2011 2:08 pm
Dynojet AutoTune for Power Commander V RidersDiscount Riders Discount 0 Apr 1st, 2010 8:14 am
Power Commander with AutoTune Oahu_fighter_pilot StreetFighter 35 Jan 27th, 2010 5:13 pm
