I''ve been looking for cheap solutions to the hypermotards ground clearance problem. First thing is ofcourse jacking the rear up, but that can only be done a certain amount without ofsetting the geometry too much.
Someone told me that S4R rearsets should fit the hyper. I've been comparing them and the mounting does look the same. They both mount to the engine and the frame. Has anyone tried this before? I'm going to see if I can salvage a rearset from somewhere to test this.
Stock S4R rearsets are higher than the Hypers, and even though they're not adjustable they should be adequate.
S4R(not stock, but the mounting is what's important):
Hyper:
