Less sensitive 1100s brake pads. - Ducati.ms - The Ultimate Ducati Forum
Old Jan 14th, 2012, 8:34 pm   #1 (permalink)
Does anyone know of less initial grab pads for the mono blocks?
These brakes have great stopping power but suck in a panic situation where you tend to snatch the lever. I have tried just using 1 finger covering the front but that seems unnatural and prefer to use 2 fingers. I almost binned it the other day when a cager turned left infront of me.
Do any manufacturers make an organic pad for these calipers?
RamIt is offline   Reply With Quote
Old Jan 14th, 2012, 8:47 pm   #2 (permalink)
I know what you mean, I've been there and hit the ground when I lost the front end. If you search, there are numerous threads regarding this. I have new found respect for my Hyper and tip tow in the rain.
2008 Hypermotard S
2010 Multistrada S Touring
2009 BMW R1200 GS
Willie B is offline   Reply With Quote
Old Jan 14th, 2012, 8:51 pm   #3 (permalink)
Cudacharger's Avatar
+1
Cudacharger is online now   Reply With Quote
Old Jan 14th, 2012, 8:58 pm   #4 (permalink)
Akasam's Avatar
If you don't like your brakes I'll trade you my stock evo brakes for yours.
Sent from my Motorcycle iPad app
2010 Hypermotard 1100evo
Re-flash, PCV, AutoTune, MWR Lid, LV Decat, Fresco Exhaust, Ohlins Steering dampener,
Exhaust
http://youtu.be/F7O6h4i9jFo
Awesomeness
http://youtu.be/QELv_MCBG3c
Akasam is offline   Reply With Quote
Old Jan 14th, 2012, 11:23 pm   #5 (permalink)
sick50ford's Avatar
You could try notching out the pads to remove some contact area
Old Jan 14th, 2012, 11:25 pm   #6 (permalink)
nickd64's Avatar
it's called ABS .....
Nick - 2008 Hypermotard S
nickd64 is offline   Reply With Quote
Old Jan 15th, 2012, 7:55 am   #7 (permalink)
Drinky's Avatar
Images: 3
I haven't had any problems with mine in the rain. Rain was pouring but I could still hit the brakes hard enough to get my rear end to lift slightly. As long as you build the brakes instead of snatching them it shouldn't be a problem. It's a reflex though and a hard one to get rid of, but once you do
Old Jan 15th, 2012, 8:21 am   #8 (permalink)
Old Fast Guy
TOP_DUC's Avatar
I don't recall ever being in a "panic" situation and "snatched" the lever (50+ years of riding). It is a motorcycle, not a car, and as such requires a slightly different application of skills. I recommend you practice watching the traffic a bit more and always have a plan in your head for what you're going to do and there will never be a "panic" situation. A bit of practice with one finger braking, not just to cover the lever, but use ONLY one finger on the front brake lever, you will be better off IMO. My 1198SP and 1100SP only require one finger to hit maximum braking force. Brembo brakes are awesome!
There is a video floating around here somewhere of a guy "panicing" and "snatching" the front brake lever on a track and the bike doing several front-endos off the track.
`11 1198SP SBK Red; w/Termi exh; Redline flash + PC-5 tune; Sargent; Shift-tech, EVR(airbox), CDT, & BST(wheels) carbon; FBF 14/39 QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf... 170whp/98wtq
`12 1100SP EVO Hyper CORSE; w/Termi exh; Ducshop Stacks; Redline flash + PC-5 tune; FBF 14/41 QC; Shift-tech, CDT, Star, & BST(wheels) carbon; R&G; SF bars; ProGrip; Antigravity; SC Project; Ducabike; Duc Perf slipper; screen, str damper, seat, cat delete... 95whp/75wtq
TOP_DUC is offline   Reply With Quote
Old Jan 15th, 2012, 11:26 am   #9 (permalink)
08hyper's Avatar
Call Braketech, they may have organic pads for your Hyper, & start looking at different MFG's brake pads for different compounds.
I am using Braketech cast iron rotors, with their ceramic/organic race pad, really excellent feel with no hard intial "bite" & works even better when hot, but this is a very expensive way to go. Aloha Alex
Old Jan 15th, 2012, 2:50 pm   #10 (permalink)
johnchypermotard's Avatar
ciao alex ...
are the axis rotors the ductile iron rotors they make? if yes, did you need to run spacers on the caliper mounts?
Can brake pads absorb brake fluid desmo2008 Superbikes 12 May 27th, 2011 10:55 am
Brake Pads! DrGonzo Superbikes 12 Jul 31st, 2010 12:55 am
new brake pads ... johnchypermotard HyperMotard 12 Sep 2nd, 2009 12:52 am
how to bed in new brake pads jcns Superbikes 5 Jul 13th, 2009 4:05 pm
Oops - Brake Fluid on the Brake Pads Kernel_Panic Sport Touring 3 Oct 13th, 2007 12:56 pm
