Safe RPM - Ducati.ms - The Ultimate Ducati Forum
Old Jan 13th, 2012, 11:06 am   #1 (permalink)
Akasam's Avatar
Safe RPM
So I got my ECU flashed and the RPM cut off is 9500 now. How safe is the engine at this RPM?
2010 Hypermotard 1100evo
Re-flash, PCV, AutoTune, MWR Lid, LV Decat, Fresco Exhaust, Ohlins Steering dampener,
Exhaust
http://youtu.be/F7O6h4i9jFo
Awesomeness
http://youtu.be/QELv_MCBG3c
Akasam is offline   Reply With Quote
Old Jan 13th, 2012, 11:22 am   #2 (permalink)
supersport99's Avatar
How high did it get before?
supersport99 is offline   Reply With Quote
Old Jan 13th, 2012, 11:41 am   #3 (permalink)
Old Fast Guy
TOP_DUC's Avatar
Originally Posted by Akasam View Post
So I got my ECU flashed and the RPM cut off is 9500 now. How safe is the engine at this RPM?....
Hmmm? How "safe"? Kinda like "almost" pregnant... Mine is set to 9800 rpms and the limiting component is the connecting rods. They will be "ok" unless you have changed other components to significantly increase the power output at those rpms.
I asked for mine to be raised as high as possible, not for more power, but to extend the rev range for rideability/handling performance. The power drops off pretty big up there with OEM cams, so you won't be going up there for acceleration. The benefit IMO, is that the power doesn't end abruptly at 8250 and upset the chassis in the heat of "battle".
`11 1198SP SBK Red; w/Termi exh; Redline flash + PC-5 tune; Sargent; Shift-tech, EVR(airbox), CDT, & BST(wheels) carbon; FBF 14/39 QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf... 170whp/98wtq
`12 1100SP EVO Hyper CORSE; w/Termi exh; Ducshop Stacks; Redline flash + PC-5 tune; FBF 14/41 QC; Shift-tech, CDT, Star, & BST(wheels) carbon; R&G; SF bars; ProGrip; Antigravity; SC Project; Ducabike; Duc Perf slipper; screen, str damper, seat, cat delete... 95whp/75wtq
TOP_DUC is offline   Reply With Quote
just when we thought it was safe ... johnchypermotard HyperMotard 17 Nov 22nd, 2009 4:14 pm
Is this safe? desnudo1 HyperMotard 14 Mar 27th, 2008 2:46 pm
