Jan 13th, 2012, 10:19 pm
#11 (permalink)
Originally Posted by Seven9Six
There has been talk of people removing the closed loop altogether...but i'm pretty sure it cannot be done. If it has...i'd like to know how. As far as i know...all the Ducati ECU's nowdays come with a closed loop and there is no way of "removing" it and replacing it with open loop mapping.
mr. mike here has a closed loop re-flash.
and for the other guy that asked i have stacks on my 796 and almost make as much power as a stock 1100.
imo the best way to go is seven9six with the auto tune. the only reason i have my set-up with custom map is i got it for free.
i didnt want to post cause it will just carry on to long so i will make it short. a generic map is just that.doesnt take in account of altitude out side temp and other things that come into play when tuning. it can get you close but not all the free power you have at tap.
and ducati can and never will have a fix for the low end issues as they have to do that to be able to sell the bike in America. (called emissions)
keep on trucking!!!!!!
2010 black 796
dont make me badge you!!
Jan 13th, 2012, 10:50 pm
#12 (permalink)
motowheels and pro italia told me they will reflash and remove the close loop. are they wrong? is there no way of removing it even with a reflash?
2010 Hypermotard 796 with Termi 2–2 slip-ons + LV Decat + reflashed ECU + KN filter. 14T sprocket
Jan 13th, 2012, 11:33 pm
#13 (permalink)
I just got my ECU back from Motowheels and it is all open loop. The auto tune is doing its thing perfectly. I am dialing in the maps as we speak. A long ride; trying to get all the throttle positions with 30-60 secs in-between and a long road where you can go WOT a few times and you will see the map change. When you get back from the ride send the map to the PCV and repeat. Do this a few times and you will have the next best thing from a custom DYNO tune.
Jan 14th, 2012, 12:28 am
#14 (permalink)
Originally Posted by vroooom
re-flashing is supposed to take care of this "shitty low end". motowheels.com has a deal on the LV decat and get the ecu re-flashed for just 99$. about $350 in total.
That is great deal! Pitty, we don't have motowheels.com in australia
Shorty toetip on a 2010 HM 796 Ducati Red
Jan 14th, 2012, 12:51 am
#15 (permalink)
is your ECU a Siemens?
Jan 14th, 2012, 12:55 am
#16 (permalink)
I am seeking stock ecu remapping locally. Can you tell me what I should tell the tech what I need to do for this re-flashing task? Remove sensor? Improve low end? Remove EU restriction? or just optimize it. etc? What should I tell them?
Jan 14th, 2012, 1:18 am
#17 (permalink)
Yes. 2010 EVO
Jan 14th, 2012, 2:56 pm
#18 (permalink)
I don't see how it's possible to erase the closed loop and make it a full open loop map. If they did that somehow it's highly illegal and they won't be doing it for very long. It's a HUGE EPA fine if they get caught. The EPA fined Dynojet a MILLION DOLLARS for doing it. That's why they sell the PC5 as an OFF ROAD product now.
Jan 15th, 2012, 8:11 am
#19 (permalink)
Old Fast Guy
[quote]
Really? You really don't get it? It is quite easy if you have access to the ECU code. You can also set it up to run in closed loop IF the O2 sensors are connected, and in full open loop if they are not connected.
Really? You didn't know that you can buy the PC5 in RACE or STREET versions?
You should get caught up with reality!
`11 Ducati 1198SP SBK Red; w/Termi full exh; Redline flash + PC-5 tune; Sargent; Shift-tech, EVR(airbox), CDT, & BST(wheels) carbon; FBF 14/39 QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf; lots of titanium... 182whp/105wtq
`12 Ducati 1100SP EVO Hyper CORSE; w/Termi exh; Ducshop Stacks; Redline flash + PC-5 tune; FBF 14/41 QC; Shift-tech, CDT, Star, & BST(wheels) carbon; R&G; SF bars; ProGrip; Antigravity; SC Project; Ducabike; Duc Perf slipper; screen, str damper, seat, cat delete; lots of titanium... 94whp/73wtq
`12 Aprilia RSV4 Factory w/Akra Titanium exh w/Race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL; Antigravity; Zero Gravity; AF1 Carbon; lots of titanium... 181whp/83wtq
Jan 15th, 2012, 5:48 pm
#20 (permalink)
Originally Posted by dimitrinassis001
So I called up the Ducati tuning shop in my area today and I was asking them about some advice about my bike and how to make it smoother and get some more power. I had told them I currently have the MWR drop in foam filter and termi pipes cat delete dp ecu. He first told me to take out my dp ecu and put in the stock siemens ECU. They will dyno and tune the stock ecu. He said he can get me 10 percent more horses on the low and mid range about 2 to 3 percent on the top range and make my hyper 796 run smooth as silk (for a twin). He also told me that velocity stacks or the MWR air box mod won't give my bike more then a couple of horses unless I had done cams and other engine internals. He explained that my motor does not get as much out of air box mods like the 1100 hyper would. Oh and the cost to dyno and tune my ECU would be around 600 bucks all in. That sounds like a lot to me (but then again you dont need a piggy back system) and this is the only legit Ducati performance shop that I know of that caters specifically to Ducati bikes. Any other informed opinions?
Which shop are you dealing with? I live in K-W and would like to talk to them about similar mods.
