Engine stall under braking. Is there a fix? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Jan 11th, 2012, 11:18 pm   #1 (permalink)
I'm sure i've posted this before but can't find the thread.
My bike is always, and I mean ALWAYS stalling on braking with half a tank of fuel or less. The less fuel in the tank, the worse it gets.
Dealer doesn't have a clue, just out of warranty, in Mexico (imagine the level of support that is available to me). Every single time the tank gets below half using MEDUIM to Hard braking the engine just dies.
What the hell is causing this this? it's driving me nuts.
A couple of times in traffic it has actually put me in a dangerous situation because once the engine dies, I can't cluth start. I have to pull the clutch and hit the starter after a few seconds.
To not have it stall I have to brake from 80km/h to around 10km/h in like 100'
This cannot be normal
'02 1450cc Sportster
'10 BMW F800R
'11 Hyper EVO SP
canicoll is offline   Reply With Quote
Old Jan 12th, 2012, 4:25 am   #2 (permalink)
vroooom's Avatar
sh*t that's plain dangerous. it's not a flywheel being too light right?
Old Jan 12th, 2012, 10:42 am   #3 (permalink)
Jmurda's Avatar
I have a 2008 hyper 1100 , and in the summer it did that for a while now on the winter has stop . I also took it to the dealer n they had no idea but hopefully urs stops too .. But I used to deal whit it wen u braking be on the clutch n give some gas at the same time n it won't shut off try it it works
Jmurda is offline   Reply With Quote
Old Jan 12th, 2012, 11:22 am   #4 (permalink)
dimitrinassis001's Avatar
Does it pop then stall?
dimitrinassis001 is offline   Reply With Quote
Old Jan 12th, 2012, 11:53 am   #5 (permalink)
No, it just dies. Exactly like fuel starvation but with half a tank, I can't see how this could be possible
'10 BMW F800R
'11 Hyper EVO SP
Old Jan 12th, 2012, 12:36 pm   #6 (permalink)
Rob H's Avatar
Have them check/replace your fuel filter.
'08 Hyper 1100
'07 DR-Z400SM
Rob H is offline   Reply With Quote
Old Jan 12th, 2012, 1:47 pm   #7 (permalink)
Already done, not the problem
'10 BMW F800R
'11 Hyper EVO SP
Old Jan 12th, 2012, 2:56 pm   #8 (permalink)
goin2leaveamk's Avatar
I have just a couple of questions. Is your clutch pulled in when this happens? What engine mods have you done if any? Has your bleed screws been adjusted?
goin2leaveamk is offline   Reply With Quote
Old Jan 12th, 2012, 3:05 pm   #9 (permalink)
Clutch engaged, termi slip-ons with DP ecu (had problem before this mod) what are bleed screws?
'10 BMW F800R
'11 Hyper EVO SP
Old Jan 12th, 2012, 3:31 pm   #10 (permalink)
This is just a thought.
When you remove the filler cap does it suck in air.
Poss blocked or inoperative filler cap air vent.
Boilerhouse is offline   Reply With Quote
M1100 EVO hopping to neutral while engine braking? gt78fin Monster 1 Oct 4th, 2011 12:33 am
engine stall after Leo Vince install John Superbikes 7 Jun 21st, 2010 8:15 pm
Engine braking vs brake braking TomT Supersport 7 Jul 4th, 2009 9:55 am
999 need help!! engine stall makorn Superbikes 8 May 23rd, 2008 3:00 pm
ECU cure for engine stall? MarcoM3 Superbikes 15 Aug 9th, 2007 2:38 pm
