On the Hypermotard with the single sided exhaust there's a gap between the back of the tank, and the under tail cover. Dirt and water fly up hit the under side of the seat, and get on the electronics. I've been puzzling over how to fix this for awhile. I was looking a a New Hyper a couple of weeks ago, and noticed it had a shield to cover the gap, but it gets removed for the race exhaust. Hurray I have one laying in my parts bin, a starting point for the mod.
The shield piece back, and front
The gap.
I removed the tool box see:
Hyper Tool Box
Took off the tail light, and muffler bracket. Then I held the the shield up and scribed the cuts. Which I did with a dremel.
Shield cut in from underneath
Muffler bracket, and plexi undertail cover mounted
Then I mounted a rubber strip acrossed the top on the inside, zip tied to either side if the frame
The underside done
Ted
