How do you get the damn cables off? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 7th, 2012, 9:26 am   #1 (permalink)
Drinky's Avatar
Images: 3
I've been fighting my exhaust valve cable cover for a few hours now, the hex bolt head is now round. I've sprayed it with WD40, oil, any other lubricant I could think of but the screws wouldn't budge, so now I'm still left with 2 cables dangling near my rear tire. I think it should be possible to remove te cables without removing the cover, right?
I'm talking about the Exhaust flapper valve. Attached to the exhaust is a small, spring loaded assembly with cables attached to it. I've managed to remove the Valve motor, but the cables are still there.
Old Jan 7th, 2012, 11:20 am   #2 (permalink)
Location: Northern, , Ireland (Ducati Hypermotard 2012 evo corse 1100)
sorry i can't help you but i'm sure that it will not be long until some of these helpful guys do
"ye must be born again" John 3 v 7
Darsey is offline   Reply With Quote
Old Jan 7th, 2012, 11:29 am   #3 (permalink)
Drinky's Avatar
Images: 3
Haha. It's always these little, unexpected things that catch you off guard and take way more time than supposed to. When I had to change my fork springs we had to remove the front fender(carbon one). Took me and the mechanic about an hour since Ducati used too much loctite and the fender was fused to the rods supporting it.
My 749 had a wellnut that joined the lower fairings together, and the wellnut was corroded. No way to reach it with a drill, so it took a bread knife and 4 hours of labor to get the nut off.
And now this. I really think Ducati just does this for fun
Old Jan 7th, 2012, 1:09 pm   #4 (permalink)
Those cables fought me as well, just use brute force and cut them off.
craighjr is offline   Reply With Quote
Old Jan 7th, 2012, 4:40 pm   #5 (permalink)
vb796's Avatar
PB blaster !!!! Works every time hands down
vb796 is offline   Reply With Quote
Old Jan 7th, 2012, 4:41 pm   #6 (permalink)
vb796's Avatar
Spray the PB on bolt or nut and walk away, have a beer or two , try again and viola' !!!!
Old Jan 7th, 2012, 6:08 pm   #7 (permalink)
Decreasing Dave's Avatar
Images: 14
+1 on the brute force and cutting tool.
I said "screw it" and just cut them after fighting with them for way too long.
They were much easier to work with after that......
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jan 7th, 2012, 7:01 pm   #8 (permalink)
Hi Guy's,
I would suggest to drill the rounded bolt head with a 6mm drill bit (not to much, just to remove the bolt head).
It would allow you to remove the cover and then the cables. Voila.
JeremyM is offline   Reply With Quote
Old Jan 7th, 2012, 8:24 pm   #9 (permalink)
Akasam's Avatar
Drill the heads off the screws. The cover will come off. Remove cables done. 5 mins total
Sent from my Motorcycle iPad app
2010 Hypermotard 1100evo
Re-flash, PCV, AutoTune, MWR Lid, LV Decat, Fresco Exhaust, Ohlins Steering dampener,
Exhaust
http://youtu.be/F7O6h4i9jFo
Awesomeness
http://youtu.be/QELv_MCBG3c
Akasam is offline   Reply With Quote
Old Jan 7th, 2012, 11:45 pm   #10 (permalink)
Images: 14
Cut cables with snips. Pull remaining pieces out with pliers.
2 minutes, 37 seconds.....
Dave
My DOC Welcome Kit
Dave Yeski
Motion Pro Cables... Who Did That!?!? Gilly StreetFighter 5 Sep 18th, 2011 11:51 pm
Red cables? Gallego Sport Classic 6 Mar 31st, 2011 10:31 am
Brake Cables slowerthan Sport Classic 5 Jan 7th, 2011 1:39 pm
Damn, Termi's are pretty damn loud.... logigeek Sport Classic 7 Jul 19th, 2010 5:26 pm
New throttle cables.... vwbuge Supersport 1 Jul 19th, 2008 8:56 pm
