Jan 3rd, 2012, 12:18 pm
oil cooler guard
I am trying to decide between the Evotech and the Cox oil cooler guard for my Hyper, does anyone have an opinion on which one is better or worse and WHY?
They are around the same price and each have a little different look, and seem to attach at different points and protect different areas (like the Evotech covers the heat sink above the oil cooler). So I am not sure which to get
Thanks
2011 Ducati Hypermotard 796
2003 Service Honda CR500AF
2001 Honda CR250R (dual sport)
2003 Honda CRF450R
Jan 3rd, 2012, 5:27 pm
I run an evotech. I like it the only problem I've found with it is that the holes are just big enough to let little pebbles in and not out. Easy solution tho used metal bug screen and a combination of 2 sided tape and spray glue on the inside of the guard. Has held up for a season so far and is actually easier to clean due to less bug guts making it onto the cooler. Haven't even looket at the cox cooler guard so no opinion on it at all.
L8r Kone
2010 Hyper 1100 Evo.
2002 Suzuki Rm265 too many mods to list
2002 Arctic Cat M8 151"x14"2.25"
2008 KingQuad 450 Axi "Mini Jeep"
Jan 3rd, 2012, 6:41 pm
I like my Evotech. It not only protects the oil cooler but the voltage regulator as well. It makes cleaning both much easier, plus it looks good too!
Jan 4th, 2012, 12:03 pm
Was thinking of getting the evotech. Do you guys think its protection thats actually needed?
Jan 4th, 2012, 12:24 pm
YES!!! Need is relative, I'm sure there lots op people on here that have run for the life of their bikes without one, but look at an oil cooler that hasn't had a guard and look at one that has and you'll probably agree it's needed. The front tire throws alot of debris onto the cooler if you ride on less than new roads you will through rocks at your cooler from the road surface, and if you ride on brand new roads the amount of tar flicked by the front wheel is incredable. The guard in my mind is a must!
L8r Kone
Jan 4th, 2012, 12:29 pm
thanks for the info, looks like i will order the evotech one
2003 Honda CRF450R
Jan 4th, 2012, 4:00 pm
I have the Evotech on my Hyper and Multistrada. The finish has held up well and they fit perfectly.
2008 Hypermotard S
2010 Multistrada S Touring
2009 BMW R1200 GS
Jan 6th, 2012, 3:52 pm
that is pretty, but for $99, I'll take my chances. I've seen used oil coolers for about that much money.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Jan 7th, 2012, 8:28 am
What sort of price are you seeing for used motors and trannys?
2008 Hypermotard S
2009 BMW R1200 GS
Jan 7th, 2012, 9:54 am
Wait, 99 bucks for a cover? You can just make them from chicken wire, will probably cost you less than $10
