Hyper 796 with the Wrench light on - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Dec 31st, 2011, 1:24 am   #1 (permalink)
vb796's Avatar
Well I guess I hit my break in service time.Wrench light is on . Taking it in tomorrow for the 1st service. Anything I should know about ? Will the bike run stronger after adjustments ? Thanks everyone !! Love thus forum
vb796 is offline   Reply With Quote
Old Dec 31st, 2011, 5:53 pm   #2 (permalink)
well...every bike is different, but my bike rode a lot smoother after the first service. Completely changed the behavior of the bike and made it far more enjoyable to ride
32vsnake is offline   Reply With Quote
Old Dec 31st, 2011, 7:38 pm   #3 (permalink)
BKK
No Change. They service the bike, they don't perform magic!
BKK is offline   Reply With Quote
Old Dec 31st, 2011, 7:56 pm   #4 (permalink)
HM1100evo's Avatar
I was told by the tech working on my bike that the rev limit is increased after the fist service. So I guess they do a little magic.
HM1100evo is online now   Reply With Quote
Old Dec 31st, 2011, 10:42 pm   #5 (permalink)
vroooom's Avatar
I believe that's not something they actually do, that's probably built right in the ECU programming. They just input the first 1000 kms service and the new higher limiter value is used plus the wrench sign disappears. I may be wrong though.
My neutral gear is still hard to locate from 1st gear. It always overshoots to 2nd... Then to N. the shop ran out of the normal dino oil that they suggest I use and filled it with a semi-synthetic instead.
Old Jan 1st, 2012, 2:45 am   #6 (permalink)
vb796's Avatar
Service done and so much smoother . Also I went to a 14 tooth sprocket and wow!! What a difference
Old Jan 1st, 2012, 11:20 am   #7 (permalink)
It's the sprocket that did all the magic not the service.
HyperDuc796 is offline   Reply With Quote
Old Jan 1st, 2012, 7:59 pm   #8 (permalink)
vb796's Avatar
Probably so on the smaller sprocket !! Bike rides so much better with way more throttle response . Thanks to all at redline performance in Yorktown ,VA .
Hyper parking light - what bulb? Yossarian HyperMotard 0 Oct 20th, 2010 5:39 pm
Does anybody have this Itegrated Tail Light for the Hyper krisnet55 HyperMotard 3 Jul 19th, 2010 12:50 pm
uh oh.... Wrench light came on on dash? i JUST had 6k service.. eingeist Superbikes 16 Apr 12th, 2010 4:04 pm
Wanted: hyper tail light infidel HyperMotard 1 May 5th, 2009 11:00 pm
Turning off the little wrench light levine98 Sport Touring 2 May 12th, 2007 10:16 am
