Dashboard Blinking Red Light - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comGraves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Old Dec 25th, 2011, 4:08 pm   #1 (permalink)
Starrblade's Avatar
I just picked up a 2008 Hypermotard 1100S and the dashboard has a red light flashing in the center top when I turn it off, thought it might go out after an hour or so but it's still flashing. Is this normal?
Thanks
Starrblade is offline   Reply With Quote
Old Dec 25th, 2011, 4:13 pm   #2 (permalink)
Normal its the immobiliser
hugh willmer is offline   Reply With Quote
Old Dec 25th, 2011, 5:02 pm   #3 (permalink)
Drinky's Avatar
Images: 3
Don't touch your Duc, you've activated its self destruct mode, it's some sort of anti-theft countermeasure Ducati has implemented.
Old Dec 25th, 2011, 6:29 pm   #4 (permalink)
The self destruct mode is activated as soon as the original owner signs the sales contract. The bllinking light simply tells you it's still counting down.
Seriously the OBD light is supposed to go out after a specified time. It's in the owners manual if you look. Off hand I've forgotten how long it takes. I'm sure if you parked your bike over night it would not be blinking in the morning.
Rick Yamane
Motion Pro
Ricoyam is offline   Reply With Quote
Old Dec 25th, 2011, 6:43 pm   #5 (permalink)
vroooom's Avatar
You need to buy an expensive upgrade for it. That's how you shut that blinking light. When it wants more then it blinks some more.
Old Dec 25th, 2011, 8:19 pm   #6 (permalink)
Mr Mike's Avatar
I do know you will need to buy a battery minder before that evil red light sucks the life out of your battery
? CUSHMAN GOLDEN EAGLE
Old Dec 25th, 2011, 10:34 pm   #7 (permalink)
You guys sure it doesn't go out by itself? Seems like mine does but I guess I could just be numb to it all.
Rick Yamane
Motion Pro
Old Dec 26th, 2011, 3:08 am   #8 (permalink)
Mine goes off after some time too
Honda Phantom 200cc 2006 --->2007
Honda Super Four 400cc 2007--->2008
Kawasaki Concours 1400cc 2008 --->2010
Yamaha X1R 135CC - 2010 ---> 2011
Honda PCX 125CC - 2011 ---> 2011
Kymco Myroad 700I - 2011 --- >
Ducati Hypermotard 1100 EVO - 2011--->
ohayo is offline   Reply With Quote
Old Dec 26th, 2011, 10:45 am   #9 (permalink)
Mr Mike's Avatar
Yes it does go off by itself and the light has no significant effect on the battery.
Its the immobilizer part that sucks battery 24/7.Kind of like when you turn off your TV it still uses power to look for a remote signal to turn it back on.
A coil located around the ignition switch creates a small magnetic field that will stimulate the proper key. This feedback then allows the bike to be stared.
Old Dec 26th, 2011, 1:45 pm   #10 (permalink)
Drinky's Avatar
Images: 3
Nope, not neccessary. My battery was hooked up to the bike when it sat idle for 1 month, battery was still full.
Blinking Instrumental Light While Parked Sputniks StreetFighter 4 Dec 20th, 2010 4:45 pm
Blinking red light slowwls StreetFighter 18 Apr 2nd, 2010 2:22 pm
Blinking red light Crank1000 HyperMotard 1 Apr 13th, 2009 2:48 pm
rear light blinking on st2 mike shannon Sport Touring 2 Dec 1st, 2008 6:19 pm
blinking RPM light cyclebrain Superbikes 6 May 19th, 2006 9:23 am
