2010 - Up Torque Values - Ducati.ms - The Ultimate Ducati Forum
Old Dec 6th, 2011, 6:57 pm   #1 (permalink)
flyinon2's Avatar
I have a 2010 Evo SP and I have been looking for the torque values. I have found the 2008-2009 numbers but not the 2010 and up. I know that most are the same but the engine and a few others are different. I realize that I can purchase the shop manual but I don't plan on doing anything other than normal maintenance like fluid changes, wheel and brake removal and tightening misc. bolts etc.
flyinon2 is online now   Reply With Quote
Old Dec 6th, 2011, 8:17 pm   #2 (permalink)
Google it
2008 Hypermotard S
2010 Multistrada S Touring
2009 BMW R1200 GS
Willie B is offline   Reply With Quote
Old Dec 6th, 2011, 9:20 pm   #3 (permalink)
flyinon2's Avatar
I already tried that. If you have a 2007-2009 model there is all kinds of info. out there, unfortunately there isn't that much on 2010 or newer yet.
Old Dec 6th, 2011, 10:21 pm   #4 (permalink)
Rikosintie's Avatar
If you are doing an oil change, the EVO uses the small oil drain plug from the 1098 so don't torque it to the same spec as the earlier model.
You can see the difference in size on the TPO site.
1098
https://www.tpoparts.com/cat093/inde...&product_id=13
'08-'09 Hyper
https://www.tpoparts.com/cat093/inde...&product_id=12
Michael
2010 1100 EVO SP
Rikosintie is offline   Reply With Quote
Old Dec 6th, 2011, 10:44 pm   #5 (permalink)
flyinon2's Avatar
1098
'08-'09 Hyper
Michael
Thanks for the heads up. Yes, I did know that the Evo uses a different torque on the drain plug than the earlier models. This is a example of why I am looking for the 2010 and up torque values. I found a pdf on here for the 2007-2009 models that it looked like someone had created from their service manual. I was hoping that someone had something similar for the Evo. I might have to break down and get the service manual CD but I am hoping that someone might have them here.
Old Dec 9th, 2011, 1:32 pm   #6 (permalink)
Tom S's Avatar
Originally Posted by flyinon2 View Post
...Evo uses a different torque on the drain plug than the earlier models.
See post #14
Damaged oil plug: Replacement
Tom S is offline   Reply With Quote
Old Dec 10th, 2011, 3:59 pm   #7 (permalink)
flyinon2's Avatar
So, what is the correct torque for the drain plug and the mesh filter? I have seen everything from 15 to 30nm for the drain plug and nothing real solid for the mesh filter either.
Old Dec 15th, 2011, 9:52 am   #8 (permalink)
flyinon2's Avatar
The shop manual for the 2010 Evo/Evo SP had the incorrect drain plug size and torque. It had the plug listed for the 2007-2009 hyper which is much larger and it also had the torque value for the larger plug which is twice that of the correct plug. Maybe that is why there is so much confusion about the torque on these plugs. The oil filter screen and plug is the same torque as the 2007-2009 bikes. I had the Service Manager at my dealer verify the torques and then I edited the copy of the torque values that he gave me. Here they are. There are 3 numbers - recommended torque, minimum torque and maximum torque. All values are nm.
Pick-up filter housing plug M32x1.5 42 38 46
Oil pick-up filter M22x1.5 42 38 46
Oil drain plug with magnet M12x1.5 20 18 22
Help with Torque Values needed. psycho_drama Sport Classic 3 Dec 6th, 2010 5:08 pm
A couple of torque values Monstyr Sport Classic 8 Sep 3rd, 2010 4:52 pm
999S torque values Turboflyer Superbikes 3 Feb 20th, 2010 2:42 am
I Need torque values. Please help! Glockem Supersport 1 Jul 1st, 2006 8:12 pm
torque values for clutch hub for 749 rustysrustyduc Superbikes 3 May 15th, 2006 9:55 pm
