Nov 26th, 2011, 1:53 pm
Any Ideas?
Just curious about what others are doing as far as radar detector placement?
I've got an Escort and previously had it mounted here (See Pic), but just installed a Fabbri windscreen and it's a little too tight. I'm worried about damaging the screen.
What have you guys done?
Nov 26th, 2011, 2:37 pm
Not much, since they're illegal here. Only legal radar detectors allowed are your eyes unfortunately
But, can't you install it in the little side fairing where the toolbox usually goes?
Nov 26th, 2011, 3:07 pm
Not sure if it's wide enough? I could mount it side ways, but then, I'm not sure if it changes it's effectivness?
Nov 27th, 2011, 7:12 am
In one of the slots of the beak?
Perhaps then you need to fabric a waterproof housing for the detector but it might work. Perphas otherwise it's possible to place only the detectors "eye" in the beak opening and extend the wires to the detector further in the beak or elsewhere on the bike. (tool cabinet).
Just an idea....
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Nov 27th, 2011, 10:41 am
awww you break the speed limit!
2K10 Hyper796 (white)
Nov 27th, 2011, 3:57 pm
Thanks for the Info guys, but I solved it. The Pic on the left was where I had the stem stand mounted to the fairing. Too tight & close to the newly installed Fabri windscreen, and it blocked out the left side of the gauge.
Pic on right is where I drilled and tapped the steering stabilizer bracket and bolted it up there. it moved it back about 60mm and left about 40mm, still keeping it behind & protected by the windscreen, and clearing up the gauge.
Nov 27th, 2011, 4:10 pm
The new view from riding position.
Gauge fully visible, screen out of harm, detector protected from view & weather behind screen, and mounted firmly to CNC steering stabilizer bracket.
Nov 27th, 2011, 5:06 pm
Nice job, very clean looking.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Nov 27th, 2011, 6:57 pm
Thanks Dave!
Nov 27th, 2011, 7:43 pm
i just added a cordless escort on my hyper used a techmount that mounts around the handlebar and is very adjustable..would easily clear windscreen..but your soloution looks titz!
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Out of Ideas
HB3 |
Monster |
0 |
Jul 6th, 2011 1:55 pm |
Help!! any ideas
goody4 |
Ducati Motorcycle Chat |
1 |
Nov 29th, 2010 1:17 pm |
Oil Ideas.
SussexDuke900 |
Supersport |
0 |
Oct 28th, 2009 3:11 pm |
HELP ideas
PastaRocket |
Sport Touring |
7 |
Nov 15th, 2007 1:02 pm |
Need some ideas....
xr1owner |
Superbikes |
8 |
Mar 31st, 2006 9:49 pm |
