Originally Posted by shamrock21
cant fix the time on bike, its 1 hour off and really bothers me. need help
dude, RTFM
but, if you are too lazy to find and read the manual:
Clock setting function
To set the clock, enter the menu page "TIME Set".
Holding button (1, fig. 8) pressed in position B “t“ for 3
seconds in this menu page gives access to the setup mode.
When you access this function, the word "AM" flashes;
pressing button (1, fig. 8) in position B "t" switches to "PM"
(flashing); pressing (1, fig. 8) in position B "t" returns to the
previous step (if clock time is 00:00, it will switch to 12:00
when you toggle from AM to PM);
pressing button (1, fig. 8) in position A "s" gives access to the
hour setting mode; hours start to flash. At each press of the
button in position B "t", hours will increase by 1 unit and
then roll over to 0; if the button is held depressed in position
B "t", hour setting will increase by 1 hour per second (hours
do not flash when the button is held depressed).
minute setting mode; minutes start to flash. At each press of
the button in B "t", minutes increase by 1 unit and then roll
over to 0; if the button is held depressed in position B "t",
minutes increase by 1 minute per second and then roll over
to 0. If the button is held depressed in position B "t" for over
5 seconds, minutes will increase by 1 minute every 100ms
(while the button is held depressed in position B "t",
seconds will not flash).
Pressing the button in position A "s", exits setup mode and
the new time is displayed.
