2011 hyper 796 Termi kit question???? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!Motorcycle.com
Old Nov 5th, 2011, 12:00 am   #1 (permalink)
Are you suppose to keep the o2 sensors in with the termi kit or remove and cap them off? Hyper 2011
mrlittle is offline   Reply With Quote
Old Nov 5th, 2011, 5:19 am   #2 (permalink)
Mr Mike's Avatar
KEEP
? CUSHMAN GOLDEN EAGLE
Old Nov 5th, 2011, 2:02 pm   #3 (permalink)
thanks,
After replacing the ECU with the DP one are you suppose to do anything else?
Old Nov 5th, 2011, 2:07 pm   #4 (permalink)
Liberator's Avatar
Originally Posted by mrlittle View Post
thanks,
Did you remove the cat?
2010 Ducati Hypermotard 796
2010 Zero S Electric
Level III Service Tech for the Rockwell Retro Encabulator
Liberator is offline   Reply With Quote
Old Nov 5th, 2011, 2:17 pm   #5 (permalink)
yes removed cat with LV
Old Nov 5th, 2011, 2:28 pm   #6 (permalink)
Liberator's Avatar
Oh cool. I have the Termi slip-on kit but have only put on the cans so far as I still have the cat. The only other thing in the kit is the air box cover right? Put that bad boy on and you should be good (but I think you have to lift the front of the gas tank for that).
And I don't think you have to worry about throttle position sensor resets since the newer bikes all have the Siemens chips which are supposed to reset the TPS at startup each time. Someone correct me if I'm wrong.
Old Nov 5th, 2011, 2:34 pm   #7 (permalink)
The kit was slipons, airbox cover and ecu all installed. was just wondering if i had to reset anything. Only drove it for a minute and got a little popping will try better ride after rain...
Thanks for the reply...
Old Nov 5th, 2011, 2:42 pm   #8 (permalink)
Liberator's Avatar
I'm not really positive on this but with the newer bikes I'm not sure you can get rid of that crappy surging/popping on decel below 4K RPM without tricking the O2 sensors with something like Dynojet's O2 Optimizer BUT maybe the DP chip already accounts for that. Someone enlighten me.
Old Nov 7th, 2011, 8:35 pm   #9 (permalink)
finally installed termi slip-on kit .......................exreamly happy Bike feels totally different,,,,,
Old Nov 7th, 2011, 8:53 pm   #10 (permalink)
Mr Mike's Avatar
New models with Siemens DO reset TP on startup. Important not to twist throttle when starting.
DP ECU does a good job of making the bike run better but does not eliminate low RPM surge.
Reflashed ECU is the least expensive fix as 02s can be turned OFF.
Remap for Full-Termi ECU on your 2011? josephvman Multistrada 2 May 29th, 2011 2:07 pm
2011 Monster 1100EVO or 2010 Hyper 796 allameriboy Monster 7 Apr 21st, 2011 1:32 pm
Monster 1100evo 2011 or Hyper 796 2010 allameriboy Welcome and Introduction 0 Apr 20th, 2011 8:21 pm
2011 Hyper color code SSR-SFS HyperMotard 3 Mar 7th, 2011 8:51 pm
Hyper won't run right since termi's grmoto HyperMotard 3 Aug 23rd, 2009 5:23 pm
