After much research I found that GPR was the best deal for the 796.
Here's some pics and comments, the instructions provided were a bit cut and paste from the 1100 and different bikes, so this may help someone combined with the GPR instructions. I sent a pic to GPR and they said I did it right
I haven't ridden with it yet, still reassembling after my crash, hopefully this weekend I can.
What you'll get in the kit. It is built for a fat bar, but has spacers for the stock bar. (sorry leaf not included)
Remove the stock bars clamps entirely
Install the part that goes behind the key using the stock bolts
Screw the stabilizer to the bottom part of the clamp by GPR, (use locktite).
With the bolts from GPR, add three washers (two from stock one from GPR) they will ALL go under the tree, the GPR washer should be on top, flat side down. Then line up the stabilizer and mount and wrench from the bottom (no locktite).
The tongue from the GPR should be about half way in the groove of the piece by the key, tighten that bolt now too.
Place the bar and top of the clamps, then on to replacing the rest of the stuff!
Also, the guy from GPR told me to ride it for a bit and do a final tighten.
