796 Termignoni Exhaust Manifold Kit Question - Ducati.ms - The Ultimate Ducati Forum
Old Oct 19th, 2011, 9:42 pm   #1 (permalink)
I know that a lot of people have been using the LV manifolds to eliminate the CAT. Will the Termignoni 796 Manifold kit work with the stock exhaust?
http://www.store.commoto.com/ducatis...s-p-99662.html
psycho_drama is offline   Reply With Quote
Old Oct 19th, 2011, 11:18 pm   #2 (permalink)
Ducati Hypermotard 796 Termignoni Exhaust Manifolds (96456210B) | Commonwealth Motorcycles Ducati &
That was me you bought the headers from. I do not think the stock collector exit is the same outside diameter as the stock collector is. Therefore you'd have to use a Termignoni can...or an aftermarket right hand side can....can like my Mivv.
Bob
Or....an adaptor would work.
Seven9Six is offline   Reply With Quote
Old Oct 19th, 2011, 11:23 pm   #3 (permalink)
dimitrinassis001's Avatar
Its like 5 times the price, that why I got the termi cans and the lv cat delete.
dimitrinassis001 is offline   Reply With Quote
Old Oct 19th, 2011, 11:29 pm   #4 (permalink)
Bob
Where can I get an adaptor?
Mivv Suono Slip-on for Hypermotard 796, PJ's Parts
Above shows a MIVV can installed with stock headers. So the Termi manifold kit is not the same size/dimension as the stock manifold?
Old Oct 19th, 2011, 11:42 pm   #5 (permalink)
So the Termi Kit will work with stock exhaust then?
Old Oct 19th, 2011, 11:55 pm   #6 (permalink)
Make one. Or buy a Tremignoni can.
Old Oct 20th, 2011, 1:26 am   #7 (permalink)
should be ok.
nevermind, it should work. if the 2-2 termignoni slip-on works with stock collectors and termi manifold kit is made to complement the 2-2 termi slip-ons, i don't see a reason why it would not work with stock cans. thanks and let me know when you ship 'em.
Old Oct 20th, 2011, 8:25 pm   #8 (permalink)
Mr Mike's Avatar
Any aftermarket Manifold LV/Arrow/ DP, will hook up to stock cans using stock mid pipe.
Will sound good but run a bit leaner.
Reflash with slip on map and have o2s turned OFF $300
? CUSHMAN GOLDEN EAGLE
Old Oct 20th, 2011, 8:41 pm   #9 (permalink)
I was told by Aldrin at Commonwealth Moto that the Termignoni kit will replace the entire stock headers/collector, no need to use the stock anything except for the cans.
Old Oct 20th, 2011, 8:47 pm   #10 (permalink)
Mr Mike's Avatar
Good to go
Termignoni exhaust fading question. johnny_boy02 StreetFighter 5 Mar 13th, 2011 6:12 am
Termignoni 2 into 1 racing exhaust question Hyper55 HyperMotard 18 Jan 28th, 2011 11:54 am
ECU Included with Termignoni Exhaust Question? Grape Supersport 6 Aug 26th, 2010 9:20 am
Question on Termignoni exhaust 1100 AAL Monster 6 Aug 15th, 2009 1:00 am
question about XX9 Termignoni exhaust buell2duc Superbikes 1 Oct 29th, 2007 12:09 am
