796 stock handlebar's geometry - Ducati.ms - The Ultimate Ducati Forum
Old Oct 8th, 2011, 4:01 am   #1 (permalink)
vroooom's Avatar
what's the closest handle bar geometry of the stock 796—the Carmichael or the Pastrana?
thanks.
Old Oct 8th, 2011, 12:34 pm   #2 (permalink)
Images: 39
I have Carmichael.
If you go Pro Taper EVO Carmicheal you will just have enough room for all stock stuff on your OEM hand guards.
This build used Pastrana though.(below)
Project Ducati Hypermotard Part III: Protection
2009 Hypermotard S Black
mangler7 is offline   Reply With Quote
Old Oct 8th, 2011, 3:06 pm   #3 (permalink)
This can help you :
Pro-Taper Contour
Bend // Width // Height //Pull Back
CR High Bend // 31.50" // 3.74" // 2.37"
CR Mid Bend // 31.50" // 3.23" // 2.24"
Carmichael Bend // 31.50" // 3.00" // 2.17"
Henry Reed Bend // 31.50" // 3.62" // 2.24"
KX High Bend // 31.50" // 4.25" // 2.21"
Henry Reed Bend //31.50" // 3.62" // 2.24"
Pastrana FMX Bend // 30.50" // 4.75" // 2.17"
Windham Mid Bend // 31.50" // 3.90" // 2.13"
Woods High Bend // 30.50" // 3.74" // 2.45"
Woods Low Bend //30.50" // 2.80" // 2.37"
YZ High Bend // 31.50" // 3.31" // 2.00"
I've had a Rizoma bar, hated it.
Now I have a Pro Taper Contour Carmichael, couldnt be happier.
Old Oct 9th, 2011, 12:01 am   #4 (permalink)
vroooom's Avatar
yeah i actually read through that build and they used pastrana but i seem to have read more guys in this forum are using carmichael.... that's what kinda made me ask. i'm just preparing myself as to what to get so when i get a damper the whole bars/clamp/damper installs together. at least that's what i'm shooting for. myb even slip the hand guards in there as well but i'm kinda liking the stock even though the mirrors are so darn wide.... which is making me not wanna bother using it. duh! i guess it'll also depend on how high the new clamp is going to bring the bars to.
i measure my stock's width and it comes to 800 roughly just to the end of the grips. but i can't measure anything else accurately. looks like the pastrana has 2 versions according to protaper.com and it's also flatter but total rise it's roughly the same to the carmichael.
Old Oct 24th, 2011, 9:24 am   #5 (permalink)
vroooom's Avatar
for the guys that went with the Carmichael bend.... why the Carmichael instead of Pastrana?
Old Oct 25th, 2011, 11:41 am   #6 (permalink)
Decreasing Dave's Avatar
Images: 14
Multi-time champion...
His only deficit against Pastrana is the backflip...
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Oct 25th, 2011, 11:51 am   #7 (permalink)
vroooom's Avatar
:d :d :d
Originally Posted by decreasing dave View Post
multi-time champion...
His only deficit against pastrana is the backflip...
Dave
Old Jan 16th, 2012, 12:31 am   #8 (permalink)
What's the final answer on the width of Hyper bars?
Specifically I'm curious about a 2009 1100 - from end to end, about 32" ??
JCM5 is offline   Reply With Quote
Old Jan 16th, 2012, 2:15 am   #9 (permalink)
What is the reason of replacing stock handlebar? It is not bad for me.
Shorty toetip on a 2010 HM 796 Ducati Red
Stock exhaust/pipe --> LV decat($261)+stock can
Stock air box/filter --> KN filter($64)+Lid removed
Stock rear fender/plate holder --> evotech tail tidy (ebay $104)
Stock mirror/handguard
Stock ecu --> PCV+opt($350)
Stock map --> Dyno map ($350)
Stock handle bar
Stock seat --> Custom lowered (DIY) + upholstery touch up($80)
Stock fork --> Andreani (Group) Fork ($1300)
Stock shock
Stock fairing --> DIY black-tinted windscreen($25) + chinese fake carbon rear hugger ($160) + DIY hugger extension ($16) NEW
Stock sprocket --> stock front+44T supersprox rear($150)
Stock levers --> MC short levers (ebay $58)
nethern is offline   Reply With Quote
Old Jan 16th, 2012, 8:44 am   #10 (permalink)
vroooom's Avatar
the 796 uses a smaller size steel tubing 7/8" (22mm) and not the 1-1/8" that's the norm for "real" bikes. . i've heard that it's like butter and one drop is all it takes for it to become bent but that wasn't my main reason. i bought a GPR that has a clamp that takes a 1-1/8 so i went and bought a pro taper—the Pastrana. unfortunately the area that is straight and takes all the controls is short. it's only about 7" and the stock is almost 8.5"—9". the total width is the same @ 800mm. so now i have a nice handlebar gathering dust. i ended up asking a buddy to machine me a spacer to make the 7/8 fit in the 1-1/8 clamp.
ah so it's actually mangler that gave me a warning on the length of the area for the controls. mangler, would you have a photo of yours?
Stock 796 handlebar dimensions ktrides2 HyperMotard 1 Aug 10th, 2011 10:19 pm
Stock handlebar size? flyinlow1 StreetFighter 1 Jan 18th, 2010 3:57 pm
GT1000 Stock Handlebar Info cabmilw Sport Classic 6 Jun 11th, 2009 3:54 pm
ST2 Forks for GT, enough space below stock handlebar? desmo_alf Sport Classic 2 Oct 29th, 2008 10:19 am
Stock handlebar adjustment? doug-b Sport Touring 6 Sep 27th, 2006 7:46 am
