Correct removal of harness from injector? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 1st, 2011, 12:02 pm   #1 (permalink)
Liberator's Avatar
Hey all,
Trying to install my PCV. I'm well known from breaking stuff by ham handing it and I wanted to ask the correct procedure for removing the wiring harness from the injectors. Never messed with a connector like this before and I don't wanna destroy anything. I see that there seem to be safety tabs on either side and what I assume is a spring loaded clip.
2010 Ducati Hypermotard 796
2010 Zero S Electric
Level III Service Tech for the Rockwell Retro Encabulator
Liberator is offline   Reply With Quote
Old Oct 1st, 2011, 12:12 pm   #2 (permalink)
Liberator's Avatar
May have answered my own question.
Ah, pop off the clip with a couple of small screwdrivers. Pry up a little and use the second screwdriver to get under it. It's slightly different from the one of the PCV harness and damn is it hard to see in there.
Threads here: Fuel Injector Electric Connector Removal and here: PCIII and quick release fuel clip question
Old Oct 1st, 2011, 9:11 pm   #3 (permalink)
cr500erider's Avatar
How did you go?
were you able to sort it all out without breaking anything???
cr500erider is offline   Reply With Quote
Old Oct 1st, 2011, 10:46 pm   #4 (permalink)
Liberator's Avatar
Lol, yeah, everything worked out great. Shocked actually. Small space, big hands, bad light, bad attitude, and low temperatures are usually a bad combination.
Injector harness removal samw5 StreetFighter 4 Sep 24th, 2011 12:29 pm
Injector needles removal arnego2 Supersport 0 Dec 22nd, 2009 1:17 pm
Fuel Injector Electric Connector Removal AXE HyperMotard 3 Dec 14th, 2008 8:05 pm
Fuel injector removal Geof3 Superbikes 0 Jul 28th, 2008 9:24 pm
Anyone know if this is the correct DP ECU TheSherThang Ducati Motorcycle Chat 0 Jul 17th, 2006 5:35 pm
