Broken Instrument panel - Page 3 - Ducati.ms - The Ultimate Ducati Forum
Old Feb 22nd, 2012, 11:22 am   #21 (permalink)
Phober's Avatar
No, I finally was able to get in touch with the manufacturer, but they wouldn't sell me the LCD part. What I ended up doing was just put it back together, plugged it in and hid it - and wired up a Trailtech Vapor unit.
It was a piece of cake to get apart, but yes you do feel like you're gonna break it. And I actually did put a little crack in the plastic in the process. The two halves are siliconed together. I put the one half in a vice, and pried and chiseled it off. Might help to heat it up first.
2009 Hyper 1100
Phober is offline   Reply With Quote
Old Feb 22nd, 2012, 12:16 pm   #22 (permalink)
Extended Member
CAlexio's Avatar
yea, heat it up and it comes right off. amazing how difficult this whole Hyper dash issue is no?
Old Feb 22nd, 2012, 12:21 pm   #23 (permalink)
JFB1973's Avatar
Thanks guys.
Will try that.
JFB1973 is offline   Reply With Quote
Old Feb 24th, 2012, 11:44 am   #24 (permalink)
Originally Posted by CAlexio View Post
STOP! unless you absolutely want the immobilizer, don't go spending thousands of dollars on ignition etc... you can reflash the dash, bypass immobilizer and be ok with just a few hundred dollar dash... doesn't have to be virgin.
I am going through same project/problem right now.
Also, here is a great way to do it yourself and keep immobilizer as well actually:
message from Gilly on this forum: "using DucatiDiag. Free software. You just have to purchase two common cables via amazon. Flash license is $140 ($100 Euros), which lets you disable the immobilizer, upload maps, change rev limiter etc.
It's all in my "Oh My" thread on the SF board.
http://www.ducati.ms/forums/138-stre...0-oh-my-5.html
If you want to flash additional ECU's, it's just 50 Euros each.
The software was written by "JP" of France. And it works. There are also options to re-virginize the ECU I believe, which in the case of a different dash, would allow you to keep the immobilizer. I'm not 100% on that part... but all the rest is gold!
__________________"
I still need to do it, but before spending all that money, look into this solution
I went to the SF board and searched Oh my, and came up with nothing. Also clicked the link and it twas dead. I could use some more info on this. Smashed my dash last july...
Would I go back to the OEM closed loop ecu, be able to dial that in, and go back to O2 sensors? and ditch pc3?
2008 Hyper S, woodcraft rearsets, DP cams, Nichols lightweight flywheel, termi 2-1, ducshop hyperstacks, pcIII dyno tuned by JPC, DP seat, and a few bits of carbon
Moline, Il
dukeraul84 is offline   Reply With Quote
Old Feb 24th, 2012, 12:16 pm   #25 (permalink)
Gilly's Avatar
Images: 17
The search engine may be case sensitive. If you look for threads started by me you will find it. I think it starts on page 5.
EDIT ********************
tHE thread.... Oh My!
search could not find it cuz it is "Oh My!" the damn effin exclamation point mo fo!!!
"Oh My!" thread link... FFS!
Old Feb 24th, 2012, 2:10 pm   #26 (permalink)
Thanks!
Moline, Il
Old May 19th, 2012, 9:31 am   #27 (permalink)
JFB1973's Avatar
How do u heat it up?
Old May 19th, 2012, 12:10 pm   #28 (permalink)
poakone's Avatar
Talk dirty to it!
L8r Kone
2010 Hyper 1100 Evo.
2002 Suzuki Rm265 too many mods to list
2002 Arctic Cat M8 151"x14"2.25"
2008 KingQuad 450 Axi "Mini Jeep"
poakone is online now   Reply With Quote
Old May 19th, 2012, 12:25 pm   #29 (permalink)
Ben710's Avatar
lol
Old May 19th, 2012, 12:48 pm   #30 (permalink)
JFB1973's Avatar
Lol lol !! Thx man gave me a good laugh!
Digital Instrument panel for 996 brklyncam Superbikes 42 May 1st, 2012 5:37 pm
WTB: 749/999 Instrument Panel ApexDreamer Parts and Accessories 5 Feb 23rd, 2011 2:47 pm
New Instrument Panel Blacked Out Sport Classic 8 Oct 19th, 2010 7:13 am
ST3 instrument panel crabbyjay Sport Touring 8 Oct 7th, 2010 6:00 pm
749 broken screws below instrument panel elliottw Superbikes 8 Jul 5th, 2010 12:11 pm
