High speed wobble - Ducati.ms - The Ultimate Ducati Forum
Old Sep 29th, 2011, 10:47 pm   #1 (permalink)
Images: 3
High speed wobble
I read some older threads on suspension. Is the suspension being to soft causing the speed wobble over 100? That seems to be my "grasp"...? Guess I just won't drive over a 100mph ...
Hattmanx
2008 Hypermotard
2001 GSXR1000
1996 ZX-9R
1982 920 Virago
1977-2009 UH-60
HATTMANX is offline   Reply With Quote
Old Sep 29th, 2011, 11:33 pm   #2 (permalink)
That wobble wouldn't likely be caused by suspension. It's worn front tire...or air pressure too low in the front....or most likely it's loose head bearings that need lubed and adjusted.
Seven9Six is offline   Reply With Quote
Old Sep 30th, 2011, 2:32 am   #3 (permalink)
Decreasing Dave's Avatar
Images: 14
....or not following the proper sequence when tightening your front wheel after removing it.
I had the same thing. Above 100mph I would get a slow "wobble", sort of like a "weave", but not a "swagger" or a "wiggle", I guess you could call it a "zig" but you wouldn't quite call it a "zag".
....but I digress....
After realigning, my "sway" went away
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Sep 30th, 2011, 5:43 am   #4 (permalink)
Moderator
stryder's Avatar
Dave
You say that with some strut.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
stryder is online now   Reply With Quote
Old Sep 30th, 2011, 5:44 am   #5 (permalink)
Images: 3
That might be the problem since I just had new tires put on....
Hattmanx
2008 Hypermotard
2001 GSXR1000
1996 ZX-9R
1982 920 Virago
1977-2009 UH-60
Old Sep 30th, 2011, 3:47 pm   #6 (permalink)
Motoman_AZ's Avatar
As mentioned in another similar thread someone suggested letting up your grip a bit when it starts to wobble and wallah...mine goes away. It also helps or is less prominent when your mirrors are folded in.....
Greg aka Motoman
www.emotoman.com
2009 Duc Hyper S
2006 Honda CRF50
2005 Suzuki LTZ-400
2005 Honda CRF450x
2003 Yamaha YZ250F
1993 Sportster Hybrid
1977 Kawasaki KZ650
Motoman_AZ is offline   Reply With Quote
Old Sep 30th, 2011, 7:48 pm   #7 (permalink)
Lifetime Premium
fireman1251's Avatar
Cheap shitty front tires will do that. Get the expensive sticky stuff, give it some gas and you'll be fine
fireman1251 is offline   Reply With Quote
Old Oct 5th, 2011, 3:02 pm   #8 (permalink)
high speed wobble
hi guys i found that my hyper would do just that i thought since i had come off it i had damaged the front end somehow ,, but i found if i sat different and put more weight on the front end it was more stable also its right about the mirrors ,,,, soppose its a wide set of bars acting like a sail ?? cheers
richie2fast is offline   Reply With Quote
Old Oct 5th, 2011, 3:22 pm   #9 (permalink)
Dave
What is the proper sequence ?
Old Oct 5th, 2011, 3:46 pm   #10 (permalink)
Drinky's Avatar
Images: 3
also depends on the geometry of the bike. I've raised the rear of mine and it wobbles a bit at 180+ kmh. It is now at 5 threads showing, didn't wobble at 4 threads, but bottomed out earlier so until. Also, a shitty tire will do this, or differently calibrated front forks.
low speed surging and high speed lugging meloman Monster 29 Mar 25th, 2011 9:38 am
Do you have a high-speed SF commuting vid? yamalink StreetFighter 21 Jan 26th, 2011 10:12 pm
High speed flat tire jdurward StreetFighter 42 Nov 23rd, 2010 9:46 am
High speed pics orangerocket Photography 25 Jan 6th, 2009 5:51 pm
Speed Wobble after pulling engine peckas Supersport 6 Mar 20th, 2007 11:26 pm
